U1262 SCP Cmmunication bus failure - Ford Truck Enthusiasts Forums
Old 07-28-2011, 07:05 AM
omanalansan omanalansan is offline
omanalansan is starting off with a positive reputation.
2002 Dually CC 7.3
After searching high and low on the internet for a fix for this code, can't find any threads that fixes it. I read some people say, "you need the stealership for this one". ouch
Any suggestions? She starts and drives fine
I do have a AE scanner..
Many thanks
-O
thanks again in advance.
Old 07-28-2011, 09:39 AM
Just found one post stating it the truck migh thave a partial burt PCM and to just replace the PCM
can somone please school me on PCM's? Are all 2002 F350 PCM's the same? or do i need to pull my PCM and see the number i need?
Old 07-28-2011, 11:10 AM
lostmybeer's Avatar
lostmybeer lostmybeer is offline
Have a nice Beer!!!
lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.
They are different. What exactly, not sure. There is a code on each one. You would have to remove the bracket to find it. To remove the PCM, follow instructions for installing a dp tuner or other chip.
Old 07-28-2011, 11:34 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
There is an SCP+ and an SCP- that goes to the OBDII data link connector. I would think that if one were open your AE wouldn't be able to communicate with the PCM. Grab your VOM an check pin 2 and 10 with key of and key on-engine off. If you don't find the right potenials it could be a loose wire or bad connctor pin. Pin 16 should be hot at all times and is protected by the same fuse as the cig lighter.
Old 07-28-2011, 12:37 PM
Payson thanks for chiming in, what should I expect, checking the VOM an check pin 2 and 10 with key of and key on-engine off? If i do find resistance that means its has connectivity if it doesn't that means i have a lose wire? or?
Old 07-28-2011, 01:33 PM
PaysonPSD's Avatar
Quote:
Check with key off and then with keyon-engine off. Of course if it won't start the engine will be off anyway. But even with engine running you would see the same potentials as with key on-engine off.
To check for the voltages one lead to good ground, the other to pin.
To check for ground one lead on voltage, use pin 16 if it is hot, and the other on pin. If ground present at pin you should see the voltage from pin 16 or whatever voltage source you use. Check the voltage source you use to a good ground so you know what to expect when you check a pin for ground.
Adjustable pedal problem looking for part number or fix. myexpo02 1997-2006 Expedition & Navigator 27 12-14-2015 04:55 PM
How to fix frosted glass? ldouble619 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 12-22-2013 11:43 AM
head lights flickering on my 67 f100 kbak 1967 - 1972 F-100 & Larger F-Series Trucks 8 03-29-2007 09:12 AM
Fixing bent front truck bed???? Redeyeracing 1999 to 2016 Super Duty 12 02-09-2007 06:06 AM
rock chip repair question -- windshield 88grandmarquis General Automotive Discussion 13 03-26-2005 06:21 PM
Tags
02, 03, 1262, 1999, 2000, 2002, 2003, code, connector, data, expedition, explorer, f150, ford, jump, link, scp, taurus, u1262, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
