87 bronco ll no spark - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 07-28-2011, 02:12 AM
FlagStaffKid FlagStaffKid is offline
FlagStaffKid is starting off with a positive reputation.
87 bronco ll how do you check to see if your ECC is workig I Have no spark coming from the coil it will not fire at all I have changed the coil and still nothing no fire What can I do. please let me know thanks
Old 07-28-2011, 12:07 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
The EEC does not fire the coil. There is a module bolted to the distributor that fires the coil. It is called the TFI module, and is known to fail. Try replacing it.
Old 07-28-2011, 08:45 PM
Thank for the info. Changed the TFI and still no spark it will not fire
D.
Old 07-29-2011, 01:21 AM
Have you checked all fuses and fusible links?
Old 08-11-2011, 05:38 PM
I changed the TFI module and still no spark from coil srarted tracing wirers and found that the fuel relay has power going in and no power going out of it used a jumper wire to go from the hot yeloow wire to the red wire and it started with it running I ran a scaner on it and got some codes 14, 18, 23 and 63 can you tell what these mean thank you
Old 08-11-2011, 09:06 PM
14: Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
18: SPOUT circuit open or spark angle word failure.
23: Closed throttle TPS voltage higher or lower than expected.
63: TPS circuit below minimum 0.6 volts.
14 and 18 may be related to you changing out the TFI module. 23 and 63 may be caused by someone touching the throttle pedal during the test, or a disconnected TPS.
Disconnect the battery for around 5-10 minutes and start it back up and see what codes you get. Make sure you let it warm up fully before the test.
Old 09-13-2011, 01:21 AM
Smile
Lead Head
I Wanted to thank for your input on my 87 Bronco II We checked every thing that you said to check found some ground wires broken and found that we had two bad relays and now it runs for about 15 min. and stoped still had spark but no gas. Come to find out the the gas shut off that is located on fire wall of passengers side was bad. now it runs great ran the codes and came up no prblemit good.
Thanks again for the help
Flagstaff kid (D.W.)
92' Bronco Intermittent Run AFhunter 1978 - 1996 Big Bronco 5 05-09-2016 02:24 PM
no spark 87 250 with 302 mitchgordon96 1987 - 1996 F150 & Larger F-Series Trucks 2 12-03-2014 02:39 PM
my bronco cranks but wont start broncoboy20 1978 - 1996 Big Bronco 18 06-17-2013 01:49 AM
no spark questions f250_kinda_girl 1987 - 1996 F150 & Larger F-Series Trucks 14 05-17-2010 12:35 PM
86 351W-EFI no sprk no fire broncojames 1978 - 1996 Big Bronco 15 05-14-2010 01:17 PM
Tags
11, 1987, 29, 4x4, 87, 87bronco, bronco, check, coil, f150, fire, ford, ll, ranger, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
