No Parking Brake
No Parking Brake
My '51 F4 has no cables running from the floor lever to the rear wheels. I'm wondering how the parking brake works on an F4, since I can't find cables for this model in my searches.
Am I missing something? Does the parking brake operate the rear drums?
And take it easy on me... I'm new at this.
this should be a mechanical set-up to back of trans. when all is adjusted as needed, shoes should not be dragging on drum when in release position. if trans is leaking, shoes will become soaked, won't work that well. clean them up with brakleen. if they are REAL soaked, would be wise to remove them and either, sand clean or replace. these shoes tend to crystalise from age and heat.
I have the same e-brake set up on my 37 Airflow. When I first got it, I left the e-brake engaged and drove less than a mile. The car wouldn't go as fast and started to smoke a lot. I thought it was on fire. When I pulled over and looked, I figured out that the brake was engaged. What a dummy!
Earl's World is a good resource for a rebuild.
Here is what he did with his emergency brake like yours.
http://www.clubfte.com/users/earl/Page11.html
Edit: Here is the line about the brake material:
"On the subject of the e-brake, I haven�t been able to find a shop that will reline the steel band that goes around the drum. I�ve looked for a source of the woven asbestos lining material so I can do the job myself, and found a similar material at McMaster-Carr."
Better yet, does anyone have any idea how to find the e-brake material for a '51 F4? I can't find it, but probably just don't know where to look.
Are you referring to rear drum brakes? My truck has an e-brake on the back of the tranny. That's the material I'm looking for. It's not really a brake shoe. It's more of a brake clamp.
Brake Lining
Most big truck parts houses can get your brake band relined. Also heavy equipment and farm machinery dealers can fix you up. I think there are places like McMaster-Carr that sell lining and the rivits. I deal with Caterpillar a lot and they relined the last one for me , it was from a 59 F 600 dump.
Have A Great Day ------ Hotwrench
