No Parking Brake - Ford Truck Enthusiasts Forums
No Parking Brake
Old 07-28-2011, 12:07 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
No Parking Brake
My '51 F4 has no cables running from the floor lever to the rear wheels. I'm wondering how the parking brake works on an F4, since I can't find cables for this model in my searches.
Am I missing something? Does the parking brake operate the rear drums?
And take it easy on me... I'm new at this.
Old 07-28-2011, 12:17 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.Rusty_Old_F250 is gaining momentum as a positive member of FTE.
Quite a few old rigs had the parking brake at the back of the transmission, it's just a big drum between the tranny and drive shaft.
Don't feel bad, I once asked where the negative battery cable went! (as if I couldn't trace it out...) So your not nearly that bad!
Sam
Old 07-28-2011, 12:22 AM
Just another Joe
Quote:
Sam
Thanks Sam. I need to crawl under there in daylight and look at it again.
Joe
Old 07-28-2011, 06:03 AM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
this should be a mechanical set-up to back of trans. when all is adjusted as needed, shoes should not be dragging on drum when in release position. if trans is leaking, shoes will become soaked, won't work that well. clean them up with brakleen. if they are REAL soaked, would be wise to remove them and either, sand clean or replace. these shoes tend to crystalise from age and heat.
Old 07-28-2011, 08:06 AM
Just another Joe
Thanks Petey. I'll have to check that out. Now that you mention it, I have heard of these parking brakes before which "clamp" down on the tranny or drive shaft instead of working the rear brakes. I just didn't know that was what Ford used on this truck.
I have lots and lots to learn.
Old 07-28-2011, 09:21 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I have the same e-brake set up on my 37 Airflow. When I first got it, I left the e-brake engaged and drove less than a mile. The car wouldn't go as fast and started to smoke a lot. I thought it was on fire. When I pulled over and looked, I figured out that the brake was engaged. What a dummy!
Old 07-29-2011, 07:17 PM
Just another Joe
OK, I just crawled under and checked out the parking brake. The cable operates the clamp just fine, but the condition of the pad material is questionable. I bet they're original.
Anyone know where I might find new ones?
Old 07-29-2011, 10:20 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Earl's World is a good resource for a rebuild.
Here is what he did with his emergency brake like yours.
http://www.clubfte.com/users/earl/Page11.html
Edit: Here is the line about the brake material:
"On the subject of the e-brake, I haven�t been able to find a shop that will reline the steel band that goes around the drum. I�ve looked for a source of the woven asbestos lining material so I can do the job myself, and found a similar material at McMaster-Carr."
Old 07-30-2011, 07:28 AM
you can take old shoes to most any good brake reline shop and get this done.
Old 08-01-2011, 10:33 PM
Just another Joe
I read the entire build thread on Earl's World. What a remarkable job he is (or was) doing with Earl. My fabrication skills are nowhere near his. He remanufactured the e-brake. I would like to contact him for information about the material he got from McMaster-Carr, but I didn't see any way to do it. Any suggestions?
Better yet, does anyone have any idea how to find the e-brake material for a '51 F4? I can't find it, but probably just don't know where to look.
Old 08-01-2011, 10:36 PM
Just another Joe
Quote:
Are you referring to rear drum brakes? My truck has an e-brake on the back of the tranny. That's the material I'm looking for. It's not really a brake shoe. It's more of a brake clamp.
Old 08-02-2011, 12:12 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Joe - you're gonna have to find a local brake exchange company to do it. I did a Google search and see there are several listed in Riverside that do shoe bonding and exchanges. One of them should be able to reline it for you or refer you to somebody that will. Stu
Old 08-02-2011, 06:57 AM
what stu said. it does not matter what lining you need to replace, it is still brake material. 9 out of 10 times, unless these linings are crystallized, they can be cleaned up with brakleen and coarse sandpaper, and re-used.
Old 08-02-2011, 07:30 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.HOTWRENCH is gaining momentum as a positive member of FTE.
Talking Brake Lining
Most big truck parts houses can get your brake band relined. Also heavy equipment and farm machinery dealers can fix you up. I think there are places like McMaster-Carr that sell lining and the rivits. I deal with Caterpillar a lot and they relined the last one for me , it was from a 59 F 600 dump.
Have A Great Day ------ Hotwrench
Old 08-05-2011, 08:30 PM
Just another Joe
So I don't have my shop manual yet. Is this brake hard to remove with the tranny still in the truck?
78 F250 Front parking brake cable. Buyerz 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-27-2014 02:37 PM
1990 F53 Driveline Parking Brake Cable thewojoes 1987 - 1996 F150 & Larger F-Series Trucks 1 08-03-2013 09:16 AM
Rear park brake cables w/ 4" lift Drac 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-21-2013 07:54 AM
Parking brake cable! CNC 1999 to 2016 Super Duty 7 05-25-2012 11:24 PM
Parking brake cable. BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 5 03-30-2012 04:39 PM
Tags
1951, 37, brake, brakes, emergency, f150, ford, fords, handle, parking, parts, removal, setup, stu, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
