No Parking Brake - Page 2 - Ford Truck Enthusiasts Forums
No Parking Brake
Old 08-06-2011, 11:19 AM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
left side has anchor bolt that should be wired so as to not back out. remove this. right side has spring tension bolt that adjusts shoes, and a screw with nuts to prevent bottom shoe from dropping. remove these and you are home free. if you need to remove drum, you must pull rear driveshaft. use some pb blaster on right side hardware after cleaning any grease or rust. i suggest that if you do not have a manual, take the time to draw a picture of how things are together---before removal--- makes guessing a thing of the past. maybe even a snapshot for future reference.
Old 08-06-2011, 02:44 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Thanks! That sounds fairly easy. Probably the hardest part will be getting the 60-year old nuts and bolts to break loose. But I have lots of time and plenty of Liquid Wrench.
I like the idea of taking pictures before removal. Does anyone have that master parts catalog CD I have seen advertised? If so, is it a real duplicate of the original paper book?
Old 08-06-2011, 09:31 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
I took a bunch of pictures of my emergency brake on my 55 F250.
I don't know how similar they are but you can see them at:
Emergency Brake pictures by harrier1351 - Photobucket
Old 08-06-2011, 09:54 PM
Harrier's Avatar
Here is a diagram for you parking brake.
I got this from this manual:
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
I would highly recommend it. It's only $20 and is worth it just to look at the pictures.
For my 55 I just got the hard copy of the manual. It was cheaper than the CD's and work good. Although I use the above manual more.
Old 08-06-2011, 10:12 PM
Just another Joe
Quote:
Originally Posted by Harrier View Post
Here is a diagram for your parking brake.
Yes, that's it exactly. I crawled under again today to get a better look at it.
Thanks. Oh, and I was able to move the truck today for the first time since the tow truck parked it in my driveway. The parking brake works! Maybe not as well as I'd like, but it prevented the truck from rolling down my sloped driveway in neutral. I may get away with just removing, cleaning, reinstalling and adjusting it.
I will be getting that Master Parts catalog CD. That's the one I was asking about earlier.
Thanks again for the help.
78 F250 Front parking brake cable. Buyerz 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-27-2014 03:37 PM
1990 F53 Driveline Parking Brake Cable thewojoes 1987 - 1996 F150 & Larger F-Series Trucks 1 08-03-2013 10:16 AM
Rear park brake cables w/ 4" lift Drac 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-21-2013 08:54 AM
Parking brake cable! CNC 1999 to 2016 Super Duty 7 05-26-2012 12:24 AM
Parking brake cable. BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 5 03-30-2012 05:39 PM
Tags
1951, 37, brake, brakes, emergency, f150, ford, fords, handle, parking, parts, removal, setup, stu, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
