Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-27-2011, 09:20 PM
Shifty150 Shifty150 is offline
Garage is empty, add now
Shifty150 is starting off with a positive reputation.
1999 f150 vacum line diagram
I changed out the 4.2L v6 in my 1999 f150 but the vac lines were rotted to the max I tossed them didn't mark them thought nothing of it and now I fired it up and need a vacuum diagram to tell me were the hoses on the right side of the engine hook up to. and, where the small coolant lines/bypass?? from the heater hose conectors on the intake and engine hook up to. cuz it's leaking all over the place, knowing I'm behinde the eight ball I put water in the radiator before I figured the hose issue out. to bad there's no diagram on the shroud etc. the dealer is useless to me been there no help. hoping I can check out some ones truck where I live, or get help here.
  #2 (permalink)
Old 07-31-2011, 02:03 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, if there is a diagram to be found on the shroud ? you could try a breakers yard ! just a thought.
the chilton workshop manual is the way forward for the info, if you can lay your hands on one.
let us know how things workout, bokker.
Tags
1999, 42l, 54, diagram, engine, f150, ford, hose, hoses, hvac, illustration, line, liter, v6, vacum, vacuum, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
