what are the symtoms of a bad voltage regulator? - Ford Truck Enthusiasts Forums
Old 07-27-2011, 10:19 PM
crestfallinman's Avatar
crestfallinman crestfallinman is offline
crestfallinman is gaining momentum as a positive member of FTE.
i have been chasing my tail around trying to figure out whats wrong with my electrical system and it all seems to check out
what happens when the voltage regular goes bad?
Old 07-27-2011, 10:27 PM
Strumlute Strumlute is offline
Strumlute is starting off with a positive reputation.
Over or undercharging. Instead of putting out a consistent 13-14 volts, it can shoot up to 18, or go down to 11 or 12 volts. If it overcharges, it could hurt your battery. Undercharging will not allow your alternator to keep up with demands, like headlights, heater blower, wipers, and so on, and drain your battery.
Old 07-27-2011, 10:33 PM
well that explains everything, thank you very much!
problem with instrument cluster three on the tree 1973 - 1979 F-100 & Larger F-Series Trucks 45 10-14-2016 11:27 AM
voltage meter jumps to max dioxippus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-31-2015 09:52 PM
Buzzing voltage regulator loudfords 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-11-2015 08:36 PM
Voltage Stabilizer for Instrument panel 66 F100 ford66 1961 - 1966 F-100 & Larger F-Series Trucks 25 11-19-2011 03:53 PM
Voltage regulator pinout grams72 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-01-2010 11:48 AM
Tags
1980, 352, 66, 73, altermator, bad, f100, f150, ford, mountaineer, occur, regularor, regulater, regulator, symptoms, truck, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
