want to rebuild my 94 f150 302 motor
Old 07-27-2011, 09:12 PM
jdmcivic23's Avatar
jdmcivic23
jdmcivic23 is offline
Hey guyz i need to rebuild my 302 will it be hard and what do i need to do. help
Old 07-29-2011, 03:10 PM
White Max's Avatar
White Max
White Max is offline
Judging from your post I'm going to guess that you've never rebuilt an engine. I'd recommend picking up a book and getting familiar with the process before diving in.
Old 07-29-2011, 04:15 PM
lew52's Avatar
lew52
lew52 is offline
You need to pull the motor out , strip it down to the short block , then take it and the heads to a good machine shop to see what it needs and have it have it rebuilt , then put it back together ....Lew
Old 07-29-2011, 04:20 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
How many miles is on the motor?
Some/most can be done in your garage if you're on a budget; inspecting the bearings, journals and cylinder walls.
There really isn't anything difficult about a rebuild, it's just a little time consuming.
Old 07-29-2011, 09:52 PM
jdmcivic23's Avatar
jdmcivic23
rebuild a 302
I'm sorry guyz, yes i have rebuilt a motor an pulled a motor. it was a Honda motor, just never a v8. my ? is once the block is done do i have to use over sized piston if i get the cylinder honed i was told i do but never did that with a Honda unless i was goin bigger but in this case im not just want standard hone.
Old 07-30-2011, 03:21 AM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
That depends on the math...
bring the pistons with you when you take the block in, they will measure.and answer your question. Most likely if your motor is high mileage, you will need to go oversize pistons
jay3534
North Carolina Chapter
01-30-2013 06:33 PM
82-100
20
04-02-2009 05:58 PM
dfisher1
11-23-2004 10:20 AM
Bob_VT
1978 - 1996 Big Bronco
02-11-2001 09:03 AM
redtruck
02-10-2001 04:05 PM
Quick Reply: want to rebuild my 94 f150 302 motor
