How many mpg will a 435 save over a C6? - Page 2 - Ford Truck Enthusiasts Forums
Old 12-29-2012, 06:07 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Good to know... I felt the same way with mine, the mpg was the same between the C6 and T19
Josh
Old 12-29-2012, 07:55 PM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Running empty @ 55mph, I gained 1-1.5 mpg (hilly area & 351w), but I think the gain would be more on towing.
There was a noticeable power gain though.......more proportionally, than the fuel saving.
A few months later I swapped the NP435 for a close ratio T19.
Night & day driving difference, due to both the ratios themselves, & the reduced gaps between - also a short-throw shift into 1st, unlike the T18 & NP435.
Old 12-30-2012, 11:55 AM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Quote:
Originally Posted by nothercrash View Post
I've actually always wondered what driving in only front wheel drive would do to performance and mileage. You can do it if you twin stick the T case. With our knobby tires, and the crazy resistance these trucks put up to moving, ...etc...
NO difference, you'ld still be turning all the same parts and same tires carrying same loads with same flexing and same power needed.
Only by eliminating the turning of parts do you save, hence using 2 HI with unlocked hubs that then let front axles, front differential, front driveshaft stay still or just loaf along with minimal windage as some will do with thick grease in the transfer case. They do so at the equilibrium point where the windage of lube in the case spinning the gears creates enough force to turn the front drivetrain agaisnt frictional losses and the lube in the front differential.
Quote:
Originally Posted by ford390gashog View Post
If you are losing 500 to the converter then its bad!!! The more realistic number is about 230-320 rpms ( That is from Dave at Hughes ) consider one of their Fuel Miser conveters!! I really enjoy mine over the sloppy stock converter!! really brought the truck to life with the 1200 rpm stall and dropped the rpms at 55 mph about 200 !! Well worth the 220.00 cost of the unit and my trans temp is down over 20 degrees on the highway which is a huge help!!
Agree, 500 rpm loss to a factory convereter is way excessive at road speed. If what he's doing is power on and then power off and seeing a 500 rpm drop .... still seems high but near half of that change is in coast and is an rpm somewhat less than would show with a locked TC or clutch.
Fuel Miser converters huh? Might look into them myself when the 400 goes in.
MPG's Spoonman75 1973 - 1979 F-100 & Larger F-Series Trucks 26 11-29-2015 06:30 PM
NP435 or ZF5 in a 78-79 Bronco ManfredVonRichtofen 1978 - 1996 Big Bronco 6 09-16-2013 06:40 PM
C6 or NP435 or ZF5? Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 47 12-08-2011 08:36 PM
How do I Improve MPG? Mrfun2fly 6.0L Power Stroke Diesel 37 01-29-2010 06:50 PM
MPG with 2bbl or 4bbl? lectricman Ford Inline Six, 200, 250, 4.9L / 300 15 04-14-2005 04:02 PM
Tags
1947, 1972, 2007, c6, custom, diesel, ford, gallon, international, miles, mpg, spotter, t19, truck, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
