HELP! bad camber issues 94 F250 4WD
I had really bad negative camber and got new tires recently and wanted to have an alignment done. They said it was not possible to get it in spec as it was. I thought it needed new ball joints so I just got done doing new upper/lower ball joints and all new steering rods/ends. Obviously didn't help the camber at all. Granted, I may not have the camber sleeve set right in the upper ball joint but it can't make it as bad as it is. What do I have to do to get this thing's camber correct?
I have the same issue but not nearly as much, and only when I back up. Sorry, I'm not trying to steal your post, but maybe we could both get answers.
Any reason why my tires are straight as can be when going straight, but when backing up I get negative camber? (not as much)
on
Seeing some negative camber after backing up is normal on these trucks since you are compressing the front springs, but you should not see as much as in the pics. Have you replaced your front springs? It almost looks like it used to have a lift kit on it but they put the stock springs back on without removing the TTB drop brackets. A pic of the TTB underneath the truck would help.
on
Those sleeves have an offset hole in the middle for the ball joint stud which when turned allows the ball joint to come out or go in. An parts store carries them and they aren't hard to change. Once they are in don't tighten the nut on the ball joint all te way until you adjust the camber out. Just eye ball it and then take it to an alignment shop and they can fine tune it for you. I wouldnt drive it much as is or you will toast those tires and like everything else tires aren't cheap. Good luck
The bushings wear out in these from the twisting motion of the leaf springs in this axle set up.You need to inspect!
Pivot bushings
Leaf spring bushings ALL (the ones hidden in the front of the frame also)
The springs may also be sagging from age and either need to be replaced or re arched.
Pivot bushings
Thanks for all the help guys! So I'm going to order new front leafs, new shackles, new u-bolts, and new shackle/eye bolts. Should that do the trick?
Replacing the leafs sounds a bit scary to me. I have a lift so I was figuring put the truck up on the lift (using the frame of course), jackstands under the axle, then what? What's going to let loose and how hard when I pull the shackles/eye bolts/u-bolts?
