1997 psd injector buzz test - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-27-2011, 08:56 PM
Towster Towster is offline
Towster is starting off with a positive reputation.
I just got done with down pipe litter box clean out for the cat, and removed that ebpv, ran like it was mising intermitantly, so i hook up my ae software and did a buzz test, all sounded sharp and snappy but one i believe its # seven not bad but alittle muffled best explains it, the other give away was after idle for about five minutes , it just plain burned your eyes,the scanner says they all passed the test,,,,not convinced.???? ALITTLE MORE HELP If you can??
Old 07-28-2011, 01:45 AM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Get it up to operating temperature and run a CCT. Might give you a better idea whats happening. Can't remember off the top of my head what the sequence is on the buzz test.
Old 07-28-2011, 07:34 AM
i just watched a video somewhere here on the forum,,, a link or something, and i think the guy said ,that the buzz test goes in order 1-2-3-4-5-6-7-8. not sure either got to fined that tutorial again. thank you.
Old 07-28-2011, 04:43 PM
what is a cct?????
Old 07-28-2011, 04:52 PM
pjwoolw's Avatar
Cylinder contribution test. IIRC
Old 07-28-2011, 05:36 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Buzz test sould fire all 8 first then 1-8 in order
Old 07-28-2011, 06:50 PM
the buzz test worked well except for #7 was a little muffled, the cct was alittle odd, when i activated the test at idle after a couple seconds it acted like i shut the key off, for a fraction of a second, then back to normal, i guess what im trying to say is i would think it would try to kill each cylinder one at a time, this sounded like it killed 5 or six at once for that fraction of a second, i am using auto enginuity scan tool enhaced ford!!!, what do ya think???? How sould the contribution test work????
e99 buzz test issue keiseldiesel 1999 - 2003 7.3L Power Stroke Diesel 2 03-05-2015 10:31 AM
buzz test CREECY Strokin It! 1994.5 - 1997 7.3L Power Stroke Diesel 4 05-08-2011 08:00 AM
P1298 IDM Failure, after 75k Mod... truck still runs???? CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 14 05-13-2010 10:16 PM
Injector buzz test question Yougotthehit 1999 - 2003 7.3L Power Stroke Diesel 5 10-08-2009 08:36 PM
Buzz Test Craze 1994.5 - 1997 7.3L Power Stroke Diesel 6 02-17-2006 01:46 PM
Tags
1997, 73, 73l, 97, buzz, diesel, f250, ford, howdoyoudoaninjectorbuzztestonf25o1997, injector, injectors, location, psd, test, text
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
