Premium stereo upgrade questions??
I had a friend wire in all new Pioneer components and sub plus two amps for each. The sound is much, much better than stock.
I still have two issues that need to be resolved though:
1. Getting some whining sound from the tweeters, even when the system is off. He's going to get rid of the line drops to the amp in hopes to fix the problem and add some ground caps.
2. He hasn't been able to find the location to power the amps in time with the factory head unit. Right now the system turns off with the key. It turns back on when you turn the key to Accy but then the truck turns off power to that line after about 30 seconds. Hopefully he can get that one figured out for me so I can sit and listen to the radio without the truck running.
That's great you're satisfied with it though, you're saving yourself some money for something else down the road that you may not be entirely satisfied with...
Yes, like an unleveled truck and stock tires. Getting it leveled and adding some 35" tires. Not sure which tires just yet. Probably some Nitto 295/65R20.
Speaker Issue
Many many people are interested in speaker upgrades. Here is the problem, no one has yet put a complete upgrade together. Just a sub here, mid 5x7 there, one guy replaced tweets but had to drill a hole to do it.
This is a mod that I would like to do. I called Crutchfield and the guy I spoke with wanted to sell me an amp. I do not know much about speakers and I don't want to mess up my truck or waste money!
Hopefully one of the electronics bubbas will post a complete suggestion.
Speaker Issue
Also got Dynamat in today, gonna line all four doors, pillars and probably behind back seat,,,should be a very easy install,,, we shall see....After a month I am very, very pleased with the speakers and amp,,,had a shop do the install, very professional look, can't tell there was anything done,,,till you turn on the stereo,,,evan at very low levels, fantastic sound,,,many good brands of speakers, however if you go with the JL's I know you will be pleased,,,but the amp made a huge difference..........I may replace the sub/amp next,,,but not a huge bass fan,,,the factory sub works, but dwarfed by the new sounds
Install was on a 2011 F350CC
Speaker Issue
superrangerman2002
03-29-2005 09:13 AM
RyanExplr04
08-26-2004 04:42 AM
