Carb conversion to Non feedback - Ford Truck Enthusiasts Forums
Old 07-27-2011, 09:43 AM
whisler whisler is offline
whisler is gaining momentum as a positive member of FTE.
Hello all. I have a 1984 F150, 4x4, 351W, C6, 3.55LSD with electronic feedback carb (EFC). I want to backdate it to get rid of the EFC and computer. I think i have the Duraspark conversion mapped out but was curious if it is feasible to convert the EFC to non EFC or am I better off just picking up a used carb and rebuilding. If converting is feasible that might save some money as I am retired. Anyone ever tried to convert a carb from feedback to Non feedback. Thanks!
Old 07-27-2011, 09:56 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have never done it, but I would imagine you would need another carb for parts to convert it, so you might as well rebuild the parts carb and use it. The electronic carb is most likely jetted differently, with a different calibration to work with the fuel supplied by the electronic part of the carb.
Old 07-27-2011, 10:11 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I haven't converted a carb, but have converted the engine by bolting on a non-feedback carb and eliminating the computer and associated wiring/sensors. The 2bbl Autolite 2150 carbs are pretty inexpensive so I'd get one and rebuild it.
Old 07-27-2011, 10:25 PM
Thanks guys. Looks like it is time to hit the junkyard and find a 2150 and the parts for the Duraspark conversion.
Old 07-27-2011, 10:46 PM
Gary Lewis's Avatar
At least in '82 the sensors and associated wiring was completely standalone, so taking it out was easy and clean.
Old 07-28-2011, 11:25 AM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
Wyowanderer is gaining momentum as a positive member of FTE.Wyowanderer is gaining momentum as a positive member of FTE.
Quote:
To swap out the feedback system to Duraspark you'll need the harness from the round-ish plugs on the inner fender to the dizzy/coil/oil and water tem senders, the coil, the module, and the dizzy.
Your present carb will work, but will run rich, so getting a used carb and rebuilding it is a good move.
The ignition system is plug and play; you'll unplug the TFI system and the DSII system will plug into the same connectors. Before you start, make sure you can adjust the dizzy for timing; some of the newer feedback systems had a "notched" distributer that couldn't be adjusted; I'm unsure how to advise you in dealing with that.
Have fun.
Old 07-28-2011, 02:57 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Lots of stuff in the sticky about DSII swaps....
Old 07-28-2011, 04:19 PM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
If you want to save money just run your current feedback Carb. I got 17 MPG on my last 200 mile road trip with a feedback carb. I dont believe it is cost effective to spend money on another carb as the pay off would take to long.
Do you have to do emission testing in your state?
Here is a good read.
http://www.ford-trucks.com/forums/91...gnition-3.html.
I dont believe you can convert a carb.
Jim
Old 07-28-2011, 04:30 PM
Gary Lewis's Avatar
Quote:
Originally Posted by JimsRebel View Post
If you want to save money just run your current feedback Carb. I got 17 MPG on my last 200 mile road trip with a feedback carb.Jim
Jim - Is your carb running in feedback mode? IOW, is your computer running it?
Old 07-28-2011, 04:49 PM
JimsRebel's Avatar
Quote:
No... I removed the computer.
The info is in the bottom of my post, in the signature line.
I did about 3 months of testing with a push button connected to the feedback solenoid, driving it full lean when ever possible. I had a DVM connected to the O2 sensor to monitor it.
After 3 months of manual operation I didnt have ANY change in my gas MPG.
And thus I will keep running the current feedback carb until it wears out.
Jim
Old 07-28-2011, 05:18 PM
Gary Lewis's Avatar
I'd do the same if I got the same results. Good test and good to know.
Old 03-13-2012, 12:38 AM
thatguy931 thatguy931 is offline
thatguy931 is starting off with a positive reputation.
Jim
How so did you run the feed back manuelly i am interested being a truck i just bought has the return fuel line cut and plugged trying to better understand the system better to get things running right it runs way rich right now
Old 03-13-2012, 12:48 AM
hello I was wondering if you would Know the answer to a question? Cand i use the computer ran dizzy with a standard none feed back carb? And second question is more of how did you get you feedback carb to run without the computer? do you have to convert to a duraspark two do that. interested in making that conversion. I have a 84 f150 4.9L auto trying to figure out what is my options are to getting it running solid and not smelling gas all the time?
Old 03-13-2012, 05:23 AM
Gary Lewis's Avatar
Quote:
I know you aren't asking the question of me, but I will answer nonetheless. You can run the "computer dizzy" with a standard non-feedback carb but you will not like the result. By saying "computer dizzy" I'm assuming you mean that you would also continue to run the computer, as that would be required to fire the distributor. However, that computer would not be happy because it would realize via the O2 sensor via which it monitors the air/fuel ratio that it is not able to change that ratio since it doesn't have control of the carb. At that point it will go into "limp home" mode and lock the ignition timing at something like 10 degrees. Your engine will run, but poorly.
As for how Jim ran that carb, he explained - he installed a push button that turn on the solenoid that the computer used to adjust the air/fuel ratio and monitored the result via the O2 sensor. Since he didn't see any benefit he took the computer out. But, when you remove a computer on these systems you must convert the ignition to DS-II. Or else you will effectively be in limp-home mode since the computer is what gives that ignition its advance. IOW, w/o the computer you have no advance.
Old 03-13-2012, 11:27 AM
JimsRebel's Avatar
If your current feedback carb is not working correctly, “smelling gas all the time”, I would just replace it with a older style carb and doing a DS2 conversion. I do not recommend putting any money into repairing a feedback carb unless you live in California and/or have to due to local emission requirements.
The feedback carb I am currently running is a replacement feedback carb I bought on ebay for $50. It was a fresh overhaul, but after I got ready to install it I realized it did not have a TPS on the front of the throttle shaft and thus was not compatible with an 1986 computer system. At this point I just got rid of the computer. I decided to keep on using the ebay feedback carb as it did not have any negative effect on my MPG.
At speed above 55-60 mph the O2 sensor indicated the mixture was lean anyway and I get 17 mpg on a road trip with speeds about 60-65 mph.
All this really just means I am to cheap to buy the correct carb.
Jim
WANTED, feedback carburetor parts FrankOXO 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-28-2017 06:45 AM
85 F150 Accelerator Cable - Odd KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 10-10-2015 11:41 AM
'86 4.9L Carb/Dist. Conversion to DSII freeisforme 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 61 09-06-2014 11:20 PM
Can I run a feedback type Carter YF carb with Duraspark 2 Ignition??? 86sixbanger Ford Inline Six, 200, 250, 4.9L / 300 42 11-10-2010 05:57 AM
Is this the right Carb for the DSII Conversion????? Arkdriver Ford Inline Six, 200, 250, 4.9L / 300 19 10-12-2010 01:57 PM
Tags
150, back, carb, carburetor, conversion, convert, converter, converting, duraspark, f150, feed, feedback, ford, list, parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
