99 7.3 no power/one bank dead
Old 07-28-2011, 02:59 AM
Mikegenuine's Avatar
Mikegenuine
Mikegenuine is offline
Originally Posted by gchavez
That is what I thought...
twtcad...you are going to have to PM Mike if you want to help him with your solenoid.
Thanks for tryin to help me out! twtcad.... No worries guys i've got one comin thru the mail once I install it I let you guys no how it goes.
Old 07-28-2011, 07:59 AM
twtcad's Avatar
twtcad
twtcad is offline
Excellent......glad you got it sorted out!
Old 08-04-2011, 03:37 AM
Mikegenuine
first all thanks for all the help...I really appreciate all the input,well I finally replaced solenoid,unfortunately no luck,so I pulled codes came up the same. So would you think I need a new injector. THANKS Again
Old 08-04-2011, 05:48 AM
Mikegenuine
I also removed #3 solenoid to see if maybe the new solenoid was a defect
And put it on to #5 but still no change. Hooked up AE still same codes.
Old 08-04-2011, 08:09 AM
tdpower's Avatar
tdpower
tdpower is offline
Did you ever inspect the wire bundle going over the drivers side valve cover? That is a common problem as it tends to rub and short out.
Old 08-04-2011, 09:23 AM
Mikegenuine
Yep! I'm going to take a look at it for the 3rd time just to be sure. Thanks
Old 08-04-2011, 07:41 PM
Mikegenuine
I checked wires,everything looks good used a bright surefire flashlight lol...N E ways I got these codes now P0273, P1293,P1274 all pointing to #5 on buzz TEST What I want to do is swap injector #3 to #5 and see if problem follows...Do I just swap it,and do I need to purge air out. THANKS
Old 08-04-2011, 08:59 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
So you are still getting the short to ground code? Sounds like you may have a wiring issue. You can test the injectors harness at the IDM connector. Unfortunately I am on my phone so I can not upload the tech bulletin. You may be able to find it with the search feature...I think the file name is "IDM replacement guide" or something like that.
Do you know where the IDM is located and how to access it?
Old 08-04-2011, 09:37 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
I believe this is the file Greg was referring to.
http://www.gbreman.com/techbulletin_103.html
Old 08-04-2011, 11:56 PM
Mikegenuine
Thanks for the link
The IDM is behind fender ds. Once I get home I'll check it out. THANKS
Old 08-05-2011, 04:27 AM
Mikegenuine
Okay Im confused when I do the test do I put red lead on IDM to injector ground,okay so where's the ground on injector,sorry I'm lost
Old 08-05-2011, 04:58 AM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
The power is common and the injectors fire on switching on and off the ground through the IDM pin #24 is common power, pin #8 is inj. 5 ground. Hope this helps
Jim...& fat Monty
  #28
Old 08-05-2011, 06:22 AM
Mikegenuine
Jim...& fat Monty
Thanks GOT it..Here's what I got #2 (3.5) #1 (3.5)
#4 (3.4) #3 (4.5)
#6 (3.5) #5 (3.3)
#8 (3.5) #7 (3.6)
I notice #3 was out of range NOTE I did replace original solenoid from #3 to #5....So the new solenoid is now on #3
THANKS AGAIN Without you guys i'll be stuck
  #29
Old 08-05-2011, 08:00 AM
twtcad's Avatar
twtcad
twtcad is offline
GB Remanufacturing - Tech Bulletin #103
You beat me to it.......yes, when I had my issue this is what I used! It's time consuming, but it's worth it to make sure it's not a wiring issue!
OOOPS.....I was a lot late......glad you figured it out!
  #30
Old 08-05-2011, 08:25 AM
Mikegenuine
Yep! great info I was just trying to figure where to test..Now i'm trying to debate if I should just purchase a new injector or harness or IDM...What do you think it maybe. THANKS
Quick Reply: 99 7.3 no power/one bank dead
