Replace Hub Actuator - Ford Truck Enthusiasts Forums
Old 11-12-2014, 07:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
Old 07-27-2011, 01:15 AM
dfboothe dfboothe is offline
dfboothe is starting off with a positive reputation.
anyone got a write up on how to change the 4wd drive actuator out on a 2004-2008 trucks? thanks for any help
Old 07-27-2011, 12:24 PM
BlueOvalDude's Avatar
BlueOvalDude BlueOvalDude is offline
BlueOvalDude is starting off with a positive reputation.
Quote:
dtboothe,
It's been so long since I've replaced a 4wd actuator on a F-150 but off the top of my head here are a few key points to the job: There should be 6 allen head or torx head screws retaining the cap. Once the cap is removed there will be a large 'C' clip inside, this may require special pliers to remove. Once this is done there are a series of collars and bushings that should be kept in order so as to simplify re-installation.
Don't forget to grease-up all pivotal components upon re-installation. I'll conduct some research later when I get home from work so I could supplement these tips. Hopefully some other forum members will be able to more thoroughly address your question before then
Old 07-27-2011, 02:25 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Dfboothe, you talking about the vacuum OWE actuator behind the steering knuckle out at the wheel
Old 07-27-2011, 02:26 PM
xjcamaro89's Avatar
I meant IWE actuator
Old 07-27-2011, 06:23 PM
yea i checked that and it won't hold vacuum
so i'm pretty sure it needs to be changed
Old 07-30-2011, 08:28 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
even has some pics and tools needed...
http://www.f150online.com/forums/200...replacing.html
EBPV Actuator A/Ox4 1999 - 2003 7.3L Power Stroke Diesel 2 04-11-2013 07:36 PM
Door Lock Actuator Smokeythebear 1997 - 2003 F150 48 11-28-2011 07:09 PM
Blend Door Actuator location Snooze Aerostar 14 08-20-2011 03:57 PM
4X4 Actuator blackhawk688 1997 - 2003 F150 1 08-10-2011 06:08 PM
Replacing power door lock actuator dmdillon 1997-2006 Expedition & Navigator 2 07-18-2006 09:22 PM
Tags
2005, 2006, 4wd, actuator, acuator, axle, buy, f150, f250, ford, forum, hub, iwe, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
