i think i destroyed my radio mounts-1994 f150-NEED HELP
so i was trying to take the stock radio out and well..i got pissed haha, so i yanked the **** outta it and it came loose...but not out...i noticed theres like a wide rail that was over it with a plastic clamp that the back of the radio is attached to but the side mounts that look like they are pryed off came with the radio but i cant see what they were attached to....
so did i total my f***ing radio mounts or can it be rigged to work haha
The rail you mentioned...Sounds like the stabilizer rail...sits on the main rear of the unit....
The tabs....Sounds like they simply keep it from sliding out of the hole....
Aftermarket radios use a metal sleeve...Slide the A/M radio into the sleeve, then the whole thing into the hole...VOILA!
yeh i already have a radio and everything..lol...and its just an empty hole hahaha, i tore everything out with some heavy duty pliers. im thinking i may be able to use some super zip-ties and zip-tie the radio to the rail thing and kinda force the faceplate it came with through the opening. haha. now that im not having a rampage bout it, im coming up with ideas.
thats what im thinking. i got some awsome speakers and what not but the radio was being a PITA. im being cheap bout this cause i gotta buy tires this week, i got some pretty gnarly ruts cut into my rear ones plus i got stuck pretty bad yesterday that ended up with my dads Z71 litterally DRAGGING my truck until my tires were on the ground...hehehe
