Ignition switch for '51 F4 - Ford Truck Enthusiasts Forums
Old 07-26-2011, 09:02 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Can anyone tell me what ignition switch was stock on a 1951 F4?
I'd like to get one with Ford keys, and the parts sites I've seen show various switches, key styles and often say they're for "pickups", so I don't know what to get.
Any help would be appreciated.
Joe
Old 07-26-2011, 10:48 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Subject to correction by the wise ones, 51 pick up (f1) and f4 should be the same. (OL-11572-A)
Old 07-26-2011, 11:12 PM
Just another Joe
Thanks. I don't have any ignition switch. It looks like I need the cylinder and keys 8A-11582-A as well as a switch housing OL-11572-A.
Joe
Old 07-27-2011, 06:02 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Looks to me like the number for your switch is right, 0L 11572-A. But the keys and cylinder are 1A 11582-A. The number you listed is shown in the 1952 Chassis Manual as correct for the 48-50s. That number crosses to the number I listed in the 1964 reprint edition. You'll also need the switch retainer spring, if it's not included with the switch, 0L 11581 (or 1A 11581-B as listed in the 1964 manual), and maybe (if you don't have it) the bezel 0L 11580. These parts are common to all models. Stu
Old 07-27-2011, 08:21 AM
Just another Joe
Thanks Stu. Just out of curiosity, what would be the difference between the 8A-11582-A and 1A-11582-A, I mean besides the first digit?
Old 07-27-2011, 08:25 AM
Today there is no difference since the later number has been substituted for the earlier number. Don't know what the original difference was. Stu
Old 07-27-2011, 08:35 AM
Just another Joe
I'm glad to hear that, since I ordered the 8A last night. I didn't see the spring in the catalog, but I wasn't looking for it either. I did see the bezel, and I'll need to order one. Thanks again for the info. This site and you knowledgeable folks are making this project "start" a lot easier. I have not really "worked" on a car since my first... a '57 Ford Custom. But I had to work on that one constantly.
Old 07-27-2011, 10:46 AM
Interesting that you found it listed on that old number. I looked in the Carpenter and Mid-Fifty catalogs and see that they don't list it at all. Who'd you order it from? Stu
Old 07-27-2011, 04:23 PM
Old F1's Avatar
Old 07-27-2011, 07:52 PM
Just another Joe
Quote:
I found it at
Obsolete & Classic Auto Parts.
Obsolete & Classic Auto Parts Online
They're not cheap, but they have a big selection.
Old 08-06-2011, 08:02 PM
Just another Joe
Changing back to Positive Ground
My truck is currently wired negative ground. It starts and runs, and the ammeter indication is backwards (goes toward discharge with higher RPM).
I want to change it back to positive ground. I think the only thing I need to do after switching the battery leads is to polarize the generator before I start it. Is this correct? I have never polarized a generator, but found these instructions:
To polarize the generator, simply make a short jumper wire to short between the battery (b or bat) and generator (g or gen) lugs on the voltage regulator. Only a split-second or a spark is required, so simply tap your jumper wire onto the lugs and pull them right back off."
Will that work? My voltage regulator is marked "ARM" "FLD" "BAT" so do I short the BAT to the FLD or to the ARM> I'm assuming the ARM is the armature and the FLD is for Field, so I want to short the BAT to the FLD. Is that correct?
And the coil looks aftermarket. Does it matter if the ground is pos or neg for the coil to work?
Wish I had paid more attention when my Dad was working on cars
when I was a kid.
Old 08-06-2011, 08:43 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
Why? You'll be running 12 volts positive ground?
Old 08-06-2011, 09:04 PM
Just another Joe
No, it's 6 volts. I'm going to leave it that way, at least for the foreseeable future. The battery is new. I'm going to rewire the entire truck, and I'm starting with this ground issue.
Replacement ignition switch bigcrunch Large Truck 1 05-08-2016 11:52 AM
Ignition switch help tbugher62 1987 - 1996 F150 & Larger F-Series Trucks 3 12-15-2013 06:29 PM
ignition switch rob8210 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-01-2013 05:40 PM
1994 F150 ignition problem joe0854 1987 - 1996 F150 & Larger F-Series Trucks 0 04-28-2012 09:13 PM
Ignition Switch Removal. 87 F-350 samahi72 1987 - 1996 F150 & Larger F-Series Trucks 4 04-23-2008 12:59 PM
Tags
12, 1951, coup, ignicion, market, mercury, switch, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
