I have a 96 F250 PSD and it has stock exhaust. ive been looking online for a set of stacks. i want to go from the turbo back with atleast a 5inch pipe off the turbo, and i like the look of the 7 inch stacks but all of the kits cost up to 1200 dollars.
Do you guys think it will be cheap to buy the parts sepreate or in a kit?
And does anyone know of a site that sells stacks cheap?
i highly doubt youll be able to fit a 5 inch pipe off your turbo. 4 is max from what i hear and thats pushin it, i have a 3 inch dp goin back to 4" then a 5 inch stack, made it all myself for about 250$ including dp, got the stack of an old kenworth for a box of doughnuts.. i suggest installing a downpipe, make some mesurements, go to your local semi truck shop and buy pipe from them and piece the thing together. just be sure you have flex pipe between the bed and the cab.
You will never well i say never but you will have to do alot of work on the firewall to get a 5" downpipe in there. There is trucks running 500hp on 3" DP
Mine is 3" off the trubo then 5" from DP to the top of the stacks
