You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Welcome aboard; have you check ebay? I usually see one or two there; I have also purchase some at swap meets as well. I usually don't worry aobut whether or not they work; I use them more eye candy than entertainment.
Hemmings Motor News / Services Offered section / Has radio repair shops listed. Buying a used radio: It may be in no better condition than the one you have now, it might be worse.
The last time I looked, no seller of used radios offers any sort of 'money back' guarantee.
If the radio has tubes and makes a humming noise when turned on, the vibrator is history.
The vibrators used with tube type radios are readily available and the same ones were used on all makes cars/trucks.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Transistor units appear in 64. Earlier units are tube and fairly easy to have fixed.
The bumper will not fit as you have a 3 bolt and the 65 is a two bolt. It can be adapted by removing the 3 bolt brackets and adding 2 bolt brackets.
I would recommend you have the tube radio upgraded to modern internals for AM FM and built in MP3 i pod interfaces. It is costly but well worth the effort as you do not then need a secondary system.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
Thanks to both of you and that's a cool upgrade to the radio, I was thinking about something like that but didn't know you could have it done. I will probably be getting all of the above including bumper. I was just guessing on the year model of the donor truck but I did notice it had 3 bolts on each side for the bumper. Where can I get my radio upgraded though?
