08 Superduty Nav Radio Swap - Ford Truck Enthusiasts Forums
Old 07-26-2011, 03:11 PM
cdiddy's Avatar
cdiddy cdiddy is offline
cdiddy is starting off with a positive reputation.
so after reading For a couple of hours I think I'm more confused. Will a OEM navigation unit from a 08 F250, plug and play in my 08 F250? I would be upgrading from the OEM 6-Disc w/aux button and Xm.
Old 08-01-2011, 10:23 PM
ItsMREMT's Avatar
ItsMREMT ItsMREMT is offline
ItsMREMT is gaining momentum as a positive member of FTE.ItsMREMT is gaining momentum as a positive member of FTE.
not sure depends on the number of connectors ur truck has I did what u did on my navi and it worked just make sure you have everything gps antenna ect
Old 08-28-2011, 01:39 AM
mountie's Avatar
mountie mountie is offline
mountie is starting off with a positive reputation.
I did one in my 08. It was plug and play. I just needed the gps antenna and mounted that to the rear of the radio using velcro. All the plugs matched.
Old 09-02-2011, 10:55 PM
MY09F250's Avatar
MY09F250 MY09F250 is offline
MY09F250 is starting off with a positive reputation.
I put a 08 mustang dd nav 6 disc in my 09 f250 last week I had to purchase a stock sat ant for the stang(pink plug) and secured it to the dash. Works perfectly. I also used an simple setup and a scc1 Sirius receiver and my ipod plugs right in as well and all is awesome
Best luck on aftermarket mirrors from where? hwybee22 Excursion - King of SUVs 23 02-15-2016 07:22 PM
Side mirrors GG03 1999 to 2016 Super Duty 6 02-22-2015 04:43 PM
oem rear sliding window!!! AllAboutDaZ 1999 to 2016 Super Duty 12 02-28-2014 05:12 PM
Need new rear diff cover for my 06 f-250 ssg510 Modular V10 (6.8l) 5 12-03-2013 02:39 PM
Will an 08 tailgate fit an 06? Metal Mulisha 279 1999 to 2016 Super Duty 5 07-09-2011 11:42 PM
Tags
200, duty, edge, excursion, f150, f250, ford, nav, navigation, oem, radio, raido, super, swap, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
