Help with codes P2614 and P2617
npccpartsman: Thats just what happened. Went to start the truck and it was a long crank and no start. When I did get it started it ran fine till a stop light and I had no power, in first gear giving throttle and no rev, tach did not move and then she takes off. Any Ideas or what to look for the next time it happens. Thanks
The symptoms you describe could be caused by several things. Has it been harder to start hot? More smoke than usual? Have you checked your FICM voltage? Has the STC fitting on the HPOP been changed. 05,6,7 trucks are notorious for that fitting to fail. There is a thread in the tech folder for a hard/no start situation that you might want to familiarize yourself with.
Jmorris1979
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
04-03-2019 06:26 PM
slpin
1978 - 1996 Big Bronco
09-29-2006 10:14 PM
