coil pack firing order - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-25-2011, 11:10 PM
mniewald mniewald is offline
mniewald is starting off with a positive reputation.
I was able to locate which of the 10 coil packs had gone bad in my v10 yesterday with a code reader from Advance Auto. It threw a code that said coil pack B had failed. After deciding that I didn't have the time or arm lenght to remove one coil pack at at time to determine which one was actuall bad I assumed that the front passenger coil was A and that the other packs on that side would have to be B,C,D and E if I was correct. I pulled the coil pack on the rear of the motor since it was easiest to reach and then started the motor and then shut it down. Read the codes and it now indicated two failed coil packs, B and E. I replugged the rear coil and started the motor, pulled the codes and it now only shows B as the failed coil pack. 10 minutes later I replaced coil pack B and the beast was running smooth as silk. Just thought I would pass this on since I couldn't find any reference to identifying coil packs on this forum other than pulling them one at a time and noticing how the motor performed. Have a great day.
Mike
Old 07-26-2011, 07:18 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
A=1, B=2, etc. It ain't hard to figure out.
Old 07-26-2011, 05:46 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Which, of course, he did figure out.
diagram showing spark plug wires to Coil pack? Jose A. Aerostar 7 04-11-2014 01:35 PM
Stuttering Help! fordcrzymike 1997 - 2003 F150 9 02-04-2013 07:17 AM
Coil pack going out pooneee 2004 - 2008 F150 7 06-01-2010 08:08 PM
Stay Away from "Wells" Brand Coilpacks Rockledge Ranger & B-Series 14 01-11-2010 10:06 PM
Will bad coil pack throw code? Superdave 1999 to 2016 Super Duty 20 06-12-2009 12:13 PM
Tags
1998, 1999, 2004, 40, 42, 46l, coil, f150, f250, fireing, firing, ford, order, pack, sport, track, v10, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
