1989 F150 4.9 Firing Order Question - Ford Truck Enthusiasts Forums
Old 07-25-2011, 09:56 PM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
Riddle me this, we have a 1989 f150 4.9 project truck for the nephew, the truck needs a lot of TLC. Been sitting for a long time, needed new fuel pump etc. New pump installed, pump now running, still wont start, back firing a lot. So we started checking the firing order to make sure no one had changed it, I do know the firing order is 153624. My hayes manual says the #1 plug should be at the 4oclock position just below the hold down screw closest to the fender however looking online, I found one site that said the #1 should be at the 3oclock position above the holddown screw closest to the fender, does anyone know which one it should be? and also did this change in the new models up to 93? I found a site that talked about a 92 which the holddown screws were in a completly different position at the 1 and 7 oclock position, so now I'm really confused.
thanks
Old 07-25-2011, 10:04 PM
firewood truck firewood truck is offline
firewood truck is gaining momentum as a positive member of FTE.
Don't be too concerned about where the manual says #1 wire should go, the important thing is that the distributor timing is correct regardless of where #1 falls. Get the engine to TDC on the #1 cylinder, check the manual timing marks on the balancer to be sure it's on TDC. Look at where the rotor is pointing in the distributor, this is where the #1 wire will go. Attach the rest of the plug wires in the correct firing order and the engine should start.
Old 07-25-2011, 10:38 PM
Liemavick's Avatar
Liemavick Liemavick is offline
Liemavick is starting off with a positive reputation.
Heres a pic of my 1990 F150 distributor labeled. I did the best I could with my phone camera in the dark lol.
http://img.photobucket.com/albums/v6...iringorder.jpg
Good luck and dont forget to check the plug wire connectors are snug on both ends.
Timing a 1999 5.4 HELP!!! deputydog03 Modular V8 (4.6L, 5.4L) 32 04-09-2016 12:06 AM
75 F100 front disc conversion & steering parts wyrm73 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-25-2016 12:24 AM
1989 F-150 Ignition Lock Cylinder Replacement East TX Tim 1987 - 1996 F150 & Larger F-Series Trucks 7 01-03-2013 03:57 PM
1963 F100 292 Ignition/Timing Issue dback3 1961 - 1966 F-100 & Larger F-Series Trucks 35 08-11-2012 08:05 PM
Injection Pump Timing 1SG Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-10-2003 10:18 AM
Tags
1986, 1989, 1990, 1996, 460, 49, 89, f150, firering, firing, ford, motor, order, pickup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
