Automatic Transmission Break-In? - Ford Truck Enthusiasts Forums
Old 07-25-2011, 09:44 PM
yz450fpilot's Avatar
yz450fpilot yz450fpilot is offline
yz450fpilot is starting off with a positive reputation.
OK boys I will be getting my truck out of the Ford dealer tomorrow with a remanufactured transmission. I have searched the forums and have not been able to locate information regarding break-in of a new transmission. Is there a recommended break-in procedure for a new transmission?
Thanks for any input!
Old 07-26-2011, 04:16 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Nope, drive it.
Old 07-26-2011, 04:30 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
my guy says to drive semi sane for the first 100-200 miles. after that drive as you normally would. not sure how much you really need to do that..but i have and have had no issues with my rebuilds.
Old 07-26-2011, 04:33 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
If it was rebuilt right it should not have any issues!! Drive it as you always would!!!
Old 07-26-2011, 04:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
There is no break in procedure required on an automatic transmission.
Old 07-26-2011, 07:47 PM
Thank you for all your input.
Old 08-08-2011, 08:13 PM
I need your help with my new remanufactured transmission. Had a factory ford remanufactured transmission put in at a ford dealer and after driving less than 200 miles there is trouble with the trans. The dealer wants to only repair the trans and I'm telling them I want another reman put in the truck which they refuse to do. Does anyone have any advise as to what i can do to get another remanufactured trans put in?
Old 08-08-2011, 11:37 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Which trans and what is the trouble?
Sometimes your insistance that it be fixed and refusal to take the malfunction as "normal" will sway them towards another full swap.
My replacement had a flare in it--"normal" for the 5R55E it seems, but I "fixed" that with some snake oil.
I also noticed they installed an in-line filter in the cooler lines. Hhhhmm, what do they fear about the new trans and their R&R job....
Old 08-09-2011, 04:34 AM
Ford requires an inline filter to maintain the warranty on remanufactured transmissions. It's impossible to get every bit of trash out of the coolers so the filter protects the new trans from debris left over from the old trans.
How Fast Should I Drive?? AtypclEngr 1961 - 1966 F-100 & Larger F-Series Trucks 22 08-25-2012 05:25 PM
Eco-Boost breakin Billyclub 2009 - 2014 F150 7 05-18-2012 10:13 AM
Break-in period for a new 6.4 ponyboy123 6.4L Power Stroke Diesel 2 07-21-2009 06:18 AM
Synthetic - when to switch? ranger4by Oil & Lubrication 8 06-29-2003 02:42 AM
engine break-in JimmyQB12 Performance & General Engine Building 4 03-21-2002 12:20 PM
Tags
2011, auto, automatic, break, breakin, breaking, breakins, f150, ford, rebuilt, tranny, trans, transmission, transmissions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
