cannot get my 4 wheel drive to work???
Here is a write up I did on diagnosing ESOF transfer case issues. Bear in mind that it is written from a 2004 perspective. The fuse numbers will be different for a '99, and in '99 there was not a 4WD Control Module, the General Equipment Module (GEM) did all that stuff.
Other than that, it is applicable.
https://www.ford-trucks.com/forums/1...l#post10605244
I don't believe the light test will occur until you start the engine.
However, you can try this. I'm not sure I entirely remember the procedure though.
Turn the key off. While holding down the trip meter reset button turn the key on. This puts the instrument cluster into a test mode. Each press of the button will cause it to do a test. One test will cause all the needles to sweep. One test will cause all of the indicator lights to come on. I don't recall the order that all this happens though. But if you do it and just keep pressing the button, after a couple presses all the lights should come on and you can see if the 4x4 light is working.
There are two ways to test the instrument cluster lights.
1) Start the engine. The 4x4 and Low lights should come on.
OR
2) Put the instrument cluster in test mode by turning the key on with the odometer reset button held down. Once in test mode, release the button, then push it until all of the instrument cluster lights come on.
OR
