E4OD problems
Old 08-10-2013, 08:27 AM
barbqman's Avatar
barbqman
barbqman is offline
Sorry smart phone misspelled should have said tps not god
Old 08-10-2013, 06:21 PM
subford's Avatar
subford
subford is offline
Originally Posted by barbqman
Could you tell me where the tps and maps is located ?
The TPS (Throttle Position Sensor) is located on the end of the throttle shaft (left end).
The shop manual says:
If you do not have a California Truck the MAP sensor is located Top RH side of the safety wall near the heater box.
If you have a California Truck then you have a MAF Sensor and it would be located at the RH front of engine compartment.
mohare7
01-26-2008 01:59 PM
BrilloDuck11
04-01-2007 05:07 PM
masseysbronco
1978 - 1996 Big Bronco
10-22-2005 03:08 PM
RoyalFord
1997 - 2003 F150
04-04-2005 01:52 PM
89ford73
10-15-2004 07:41 AM
Quick Reply: E4OD problems
