Wiring diagram for 01 F250 4WD - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-25-2011, 06:14 PM
b15addw b15addw is offline
b15addw is starting off with a positive reputation.
My truck recently got stuck in 4 low. It went right in without any issues. It will not disengage. I removed the servo motor that shifts the transfer case and was able to put wrench on shaft and get it out of 4 low.
Does anyone have or know where I can get a wiring diagram for the 4WD system so I can try and track down the issue? Checked manual and all fuses and everything seems ok. There are 2 relays mentioned in manual, but my distribution box doesn't have them. I would like to also bench test the servo motor, but not sure which pin connectors are what without diagram. Can anyone please help?
What is the transmission called in an '04 with 4wd, and does it use a shift servo? Mr Rodgers Escape & Escape Hybrid 2 10-30-2016 12:10 PM
Need Help 4wd Low dwysywd 1999 to 2016 Super Duty 3 05-30-2016 09:44 PM
Here's how to replace your Super Duty cruise control servo for cheap! dexterous 1999 to 2016 Super Duty 4 11-25-2015 08:06 AM
transmission servo diagnosis riverbasin Ranchero & 1961 - 1967 Econoline 1 10-07-2015 02:28 PM
Rear Servo Function- 4R55E Transmission easygoin4 Ranger & B-Series 10 04-05-2012 09:17 AM
Tags
03, 1997, 4wd, 87, diagram, diesel, duty, f250, f350, ford, heavy, pickup, superduty, system, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
