Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 5.0L Coyote
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
  #1 (permalink)
Old 07-25-2011, 05:04 PM
ratucker3's Avatar
ratucker3 ratucker3 is offline
2011 Ford F-150
ratucker3 is starting off with a positive reputation.
Smile 1st Oil Change 5.0
I have 2011 SCrew XLT 2WD with 5.0.....love the truck-----I am approaching 6200 miles with 41% remaining on the info service reminder.......would appreciate input on whether I should/should not go ahead and change oil now. My driving is mixed city and interstate. Truck has used no oil do date.........just a great driving vehicle.
  #2 (permalink)
Old 07-26-2011, 06:54 PM
AdamTN AdamTN is offline
2011 Ford F-150
AdamTN is starting off with a positive reputation.
When I bought my '11, I also bought a 100,000 mile warranty and service package (I wanted the warranty being it was the first model year of the engine and the dealer through in the service package). The dealer also through in the first oil change for free and wanted me to come in around 2,000 to 2,500 miles. The service package included oil changes every 5,000 miles.
I've had two oil changes now and I've watched both. One piece of advice if you're going to do it yourself, the way they've set up the oil filter you need a big oil pan or two smaller ones. When you pull the filter, oil goes off both sides of the cross member.
  #3 (permalink)
Old 07-26-2011, 07:00 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
Garage is empty, add now
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
That puts you at about 8600 miles!! That sounds like a good number to me!!! Honestly the oil life system works pretty well in these trucks and with the new GF5 oil its a hard combo to beat! If you are really curious do a UOA but I bet it comes back stellar!!!! Save your money and change it when it really needs it.
  #4 (permalink)
Old 07-26-2011, 08:34 PM
ratucker3's Avatar
2011 Ford F-150
Smile Thanks
Thank you for your input..........will continue to monitor the info center message. I'm an old man, don't drive it hard with no pulling or heavy loads.
I also purchased Ford ESP......did not buy maint agr however.
  #5 (permalink)
Old 07-27-2011, 05:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to all
I would get an oil analysis done just to make sure your engine is happy with those intervals.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC 2wd PSD ZF5- 500+hp daily driver.
1994 F-150 4x4 408w- 10.5:1, TFS heads, custom cam, etc.
  #6 (permalink)
Old 08-14-2011, 10:03 PM
TXRaider TXRaider is offline
TXRaider is starting off with a positive reputation.
I just did my first oil change @3400 miles. I wanted to do it at 3,000 but I was out of town.
Oil changes was "OK". Dang air damn in front makes it too hard to slide under from the nose (unless you're a skinny guy). I'll drive it up on some boards next time. As for the oil filter.... Ugh, it kind of sucks. The "drain" pain under it does have two spouts, I found that with only a slight angle most will come out the rear, but some did come out the front. My real bitch is trying to clean out this drain pan. I know I'm probably dripping a few drops on my drive way as I type this....
  #7 (permalink)
Old 12-20-2011, 11:12 AM
Pool Runner Pool Runner is offline
Pool Runner is gaining momentum as a positive member of FTE.
Quote:
Where do you get this done at?
__________________
2011 F-150 SuperCab, 2wd, XLT, Chrome Pkg, Coyote V8, 3.55, Limited-Slip, 18" wheel pkg, Michelins, Oxford White ext, gray interior, 145" Wheelbase. (My work truck)
2011 Subaru Outback, 2.5i, (wife's commuter)
2013 Subaru WRX, 2.5 turbo (weekend toy)
  #8 (permalink)
Old 09-27-2012, 09:39 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Its a brand new new engine still braking in, I would change it.
__________________
06 F-350 6.0L 102,000miles ARP Oil & Coolant Bypass Filters + EC-1 SCT IDP Delete Pipes Edge Insight STC & Fuel Reg Update Pluged Up-pipe No ScoopFront 2" Hitch 2.5" Front Lift Firestone Air Bags Front E-Locker Rear ARB Locker
2011 F-150 5.0L 15,000miles
0W-20 Mobil 1 Synthetic.
  #9 (permalink)
Old 09-28-2012, 02:11 PM
Quote:
Blackstone Labs
__________________
  #10 (permalink)
Old 09-28-2012, 02:55 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
If it hasn't used any oil, I'd go to 30% on the first change. Did you buy it in 2011? If so, I'd go ahead and change it.
Tags
2005, 2011, 302, 50, capacity, change, coyote, escape, f150, filter, ford, forum, hybrid, oil, remove, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
