68 steering column - Ford Truck Enthusiasts Forums
68 steering column
Old 07-25-2011, 05:44 PM
H00TY1 H00TY1 is offline
H00TY1 is starting off with a positive reputation.
68 steering column
hey guys, i have a 68 f100. I want to replace the steering column with one from the junk yard or ebay. It has power steering. I would like tilt and its an automatic. Which ones would be a direct fit? I have read in here that your installing from 71,73,77 even from a 83. Is that the way to go? I want cheap, no way paying the price for a new one..Please fill me in on easy way to go. thanks hooty1
Old 07-26-2011, 02:54 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
If you've got the saginaw p/s box, you can use any a/t p/s column from 68-79. Tilt was available only in '78/'79 and these fit also. If you've got a bendix p/s box (roughly same physical size as the manual box), I'd swap it for the saginaw box so you can use the newer columns. '80 and up columns won't fit without modification.
mike
Old 07-26-2011, 04:37 PM
Hey thanks. That's a start. I have a Saginaw in there. Now just see if junkyard has what I need. They have a 71 on site. Just arrived.
Old 08-17-2011, 06:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Since the OP's truck is a 1968 F100...
1966/68 F100/250 2WD, 1969 F100/250 2WD before serial used Bendix P/S.
1969 F100/250 2WD & F350's from serial number D96,001, 1970/72 (and etc) F100/250 2WD & F350's used Ford (Saginaw) P/S.
P/S was not available for F350's before serial number D96,001.
Old 08-17-2011, 10:03 AM
killingmachine1 killingmachine1 is offline
killingmachine1 is starting off with a positive reputation.
ok then, could you use a 70 auto collum on a 75 ?
Old 08-18-2011, 12:25 AM
orich's Avatar
orich orich is online now
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
mounting flange is not the same, But hey anything can be changed it you have a welder.
Old 08-19-2011, 09:24 AM
68murc's Avatar
68murc 68murc is offline
68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.68murc has a great reputation on FTE.
NOT TRYING TO HIJACK
I also have a steering column question about my 68'. I have a column from a 79' in there now, to fit with my 79' power steering box. I would like to go back to the 67-72 style column.....but I now have a B&M floor shifter.
I need a column that will fit with power steering and has no shift collar on the column. Is there such a thing?
Old 08-20-2011, 05:32 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Quote:
Since the firewall is basically the same steering columns from 65-79 will exchange. The spot weld cuff under the dash is deeper on the older trucks. One can use longer bolts or swap the cuff.
The big difference is that the Saginaw pump has the hose/tube connects on the top of the gear and require the column to be about 2 3/8" shorter, which most of the 73-79s are. The 70 column is most likely to be the longer of the two, and not a good candidate.
Bill ND can verify, I believe all you need to do is swap the cuff off the top of the column to one for a floor shift and you will have the smooth side.
John
Old 03-21-2013, 09:11 PM
reefmanchad reefmanchad is offline
reefmanchad is starting off with a positive reputation.
Hey y'all,I need a steering column for my 68 f100,want to get a chrome one,has manual steering,anyone know who would have one,found some on ebay,but would like more to look at,Thanks
Old 03-21-2013, 09:47 PM
70-360fe 70-360fe is offline
70-360fe is starting off with a positive reputation.
80's mustang have a tilt without a shift column, don't know about the fit. I believe 80's bronco's also have tilt without shift on column.
Old 03-21-2013, 10:46 PM
mk's Avatar
mk mk is offline
My first truck was a 72 F250 with ps/pb and 4 spd so I know those columns exist but sure don't see them very often. The 73-77 columns are almost exactly the same physically but have a different t/s switch, so that opens up your search a bit. I've got some columns and parts around here but sold my last 4 spd column head a few months ago. Another idea you could use comes from Muscle Car magazine's '409 on a dime' articles where they trimmed the shifter boss off the column and filled and reshaped it.
btw... thanks Bill, for the detail regarding bendix vs saginaw
mike
Old 03-22-2013, 06:52 AM
C3DZ-3790-A (replaced FEK-3790-AP) .. Steering Column Extension-Takes the place of the shift collar when the shift lever is on the floor / Obsolete
1961/66 F100/250 2WD 4 speed / 1966 F100 4WD 4 speed / ALL 1967/77 F100/350 4 speed // 1962/66 Falcon/Comet 4 speed / 1963/64 Galaxie 4 speed / 1963/66 Fairlane 4 speed.
1965/66 Mustang (all A/T & M/T are floor shift) / 1965/66 Galaxie/LTD 4 speed w/o tilt wheel / 1968/69 Mustang/Cougar A/T & M/T w/o tilt wheel.
No one has any NOS, but 1,660,000 1965/66 Mustang's came with it, so it's not that hard to find used.
Steering column NP435 T_Cooksey88 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-17-2016 12:23 PM
Collapsible Steering Column Options PapaMatt 1961 - 1966 F-100 & Larger F-Series Trucks 43 06-06-2015 06:45 PM
2 steering columns with steering boxes and 1 steering wheel reed1951 Ford Truck Parts for Sale 3 05-23-2015 05:34 PM
rebuilding steering column hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 8 02-23-2015 07:25 AM
68 vs. 64 Steering Column Spine svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 6 11-18-2014 04:23 PM
Tags
1968, 68, 69, colomn, column, f100, f250, flange, ford, power, rancheros, steering, swap, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
