Use tow haul and cruise control together - Ford Truck Enthusiasts Forums
Old 07-25-2011, 10:00 AM
healeyt healeyt is offline
healeyt is starting off with a positive reputation.
Hi, We are new to the Ford Family. Just bought f150 Super cab and want to tow a 28' Heartland travel trailer ultra-lite. (5290lbs unloaded). We have always used cruise control. What are your thoughts about tow haul? Should we always use tow haul when towing? Should we use it only on hills? Can we use cruise control at the same time as we are using tow haul? Thanks. T
Old 07-25-2011, 10:14 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Welcome to Ford and FTE!
Use tow/haul ANY time you are towing (or hauling) over 1000 lbs. Your tranny will thank you.
Do not use cruise control when towing unless you are on flat terrain in light traffic. Your wallet (i.e., MPG) will thank you.
I assume you have an 09 or later, BTW...
Old 07-25-2011, 02:58 PM
NotMyHusbandsF150's Avatar
NotMyHusbandsF150 NotMyHusbandsF150 is offline
NotMyHusbandsF150 is gaining momentum as a positive member of FTE.
I don't plan on towing any time soon but why would cruise control affect your mpgs? Doesn't running on cruise control usual optimize your mpgs? What am I missing?
Old 07-25-2011, 04:27 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
When towing with cruise control, the truck will do what ever it takes to maintain the set speed.
Its best for MPG to not use cruise control. The idea is to slightly slow down going up hill, and pick up speed slowly on the down hill. By maintaining throttle control going up hill, the truck will not try to down shift as much.
If the cruise is set and you hit a hill, the truck will drop 1-2 gears to maintain the speed and use more fuel doing so.
Old 07-25-2011, 11:38 PM
jimmyb08SD's Avatar
jimmyb08SD jimmyb08SD is offline
jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.jimmyb08SD has a very good reputation on FTE.
It is ok to run the cruise while in tow haul and towing. I have never noticed much of a difference in mpg's either way. I prefer to maintain speed when I can, but I guess if you try hard enough you may be able to save a few drops. I guess I am a realist, I gave up on trying to get good mpg's while towing!
Old 07-26-2011, 06:30 AM
shotgunz's Avatar
If I use CC when towing my boat, I get 11.9 MPG. If I turn CC off, I get 14.4 MPG (same route).
Huge difference? No, but when you're towing it 200 miles (one way) it adds up.
IMHO using CC is also a BAD IDEA if you're towing in any kind of traffic.
Old 07-26-2011, 07:01 AM
When i tow my 7500lb trailer, i dont use cruise control because of the MPG difference. With CC on the truck stays in 2nd on the hills and 3rd in the flats and never locks the converter.
With it off i can maintain 3rd gear on most of the hills and keep the converter locked on the flats.
It saves a couple MPG and i dont have to hear my truck drop to second gear at 65 mph.
Old 07-26-2011, 11:07 AM
Justjimmy's Avatar
Justjimmy Justjimmy is offline
Justjimmy is starting off with a positive reputation.
I have almost 12,000 miles on my 2011 5.0L FX2 and - according to my tow display, I've towed about 4,000 miles of that.
During those 4,000 miles, I've tested all sorts of combinations and below is my 2 cents on each post:
My 2 cents: Tow Haul is not needed unless you are driving in hilly areas. The tranny does just fine by itself.
My 2 cents: Totally agree
My 2 cents: Again, agree 110%
My 2 cents: I tow 8,000 pounds and I agree - for ME, the gas mileage difference is huge.
It saves a couple MPG and i don't have to hear my truck drop to second gear at 65 mph.
My 2 cents: Well put.
I've also tried Manual mode "M". That seems to work very well at highway speeds (65mph) with cruise off. This way, the tranny isn't always hunting for the better gear and I can control the shifting when I want.
I do want to add that I drive in Florida where the hills are mostly bridges so to be fair, my situation is probably different then some of yours.
My 2 cents
Old 07-26-2011, 11:12 AM
shotgunz's Avatar
Great feedback.
LOL - your "mountains" are our "molehills" (exactly the same as what someone from CO would say about our "mountains").
Old 07-26-2011, 12:10 PM
pappcam pappcam is offline
pappcam is starting off with a positive reputation.
I'd say CC is a BAD IDEA if you're in any traffic regardless of towing or not.
Using CC while towing on the highway is fine unless it's hilly or heavy traffic which, again, is the same for towing or not.
Old 07-26-2011, 12:13 PM
shotgunz's Avatar
I use it all the time in "moderate" traffic - but I'm usually in the right lane at the speed limit while everyone else is 10-15 MPH over the limit.
Old 07-26-2011, 09:10 PM
jimmyb08SD's Avatar
OK if you gotta try and save fuel while towing, please stay in the right lane with your 4 ways on so I don't run into the back of you! LOL
cruise control_tow haul troy676 6.0L Power Stroke Diesel 11 09-15-2015 05:07 PM
Towing question... Davidvc1964 6.4L Power Stroke Diesel 5 05-25-2013 06:45 AM
Always use tow/haul in a 12,000-pound ambulance? lwems 6.0L Power Stroke Diesel 13 04-28-2013 01:10 PM
Any Harm in driving in "Tow/Haul" all the time? Tylus 1999 to 2016 Super Duty 5 08-22-2012 09:45 PM
Flapping sound whporwil 6.4L Power Stroke Diesel 3 10-20-2011 09:21 AM
Tags
2011, 50, control, cruise, effect, f150, ford, gas, haul, mileage, mpg, tow, towhaul, towing, truck, van, whento
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
