Pivot bushing swap
Old 05-15-2018, 06:14 AM
1996300XLT's Avatar
1996300XLT
1996300XLT is offline
Pivot bushing swap
I have a 1996 F150 that needs the pivot bushings swapped. I already have polyurethane ones ordered.
Can they be swapped with just dropping the pivot end of the control arm down? Or do I need to pull the caliper and spring to drop the whole arm?
Are there any good write-ups or videos on how to proceed? There are only a couple of YouTube videos that I've been able to find. Watched them all. Lol.
Old 05-15-2018, 08:46 AM
mark1986F150's Avatar
mark1986F150
mark1986F150 is offline
You should plan to remove the springs for this job. Caliper and shock absorber will need to be disconnected. It's pretty easy to do. Otherwise you will be fighting them to reinstall the I-beams.
You might find that you need to disconnect disconnect the radius arms from the frame mount also. A metal drift would be helpful for lining up the pivot bushing and bolt holes in the cross member.
Old 05-15-2018, 09:15 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Coastal68
03-27-2016 05:30 PM
Dillan Reese
05-10-2012 08:50 AM
fairlaniac
01-08-2008 02:32 AM
hambeemer
12-13-2004 06:37 PM
Rstrause
11-10-2004 11:57 AM
Quick Reply: Pivot bushing swap
