03' F250 diesel water in fuel light problems - Ford Truck Enthusiasts Forums
Old 07-24-2011, 08:19 PM
bherm bherm is offline
bherm is starting off with a positive reputation.
So i'm not new to performing routine maintenance on my 2003 F250 6.0 powerstroke diesel. However, i am new to searching for replacement parts after routine maintenance goes horribly wrong.
PROBLEM: after receiving the WIF (water in fuel) light, i ordered new filters for both the rail mounted filter and engine compartment filter. i unfortunately had the stock fuel drain valve still installed and had it stripped out on me. during the process of removing it, the soft aluminum housing that holds the WIF sensor and fuel heater broke apart around the valve area.
(hopefully) THE SOLUTION: I need some assistance from you other members. hopefully this hasnt happened to you. but if it has, is there any way to order just that assembly area and what part number am i looking for. i have spent hours researching a new fuel filter housing assembly. my only other option i can think of is to visit a local junk yard here on cape cod and borrow one off a similar truck. i just really only need the part that is held on by the four small bolts that has the four fuel lines intersecting into the filter area.
ANY HELP IS GREATLY APPRECIATED. if you live on cape cod and can assist any further. i'm willing to go as far as to buy some cold beers for help.
Old 07-24-2011, 10:19 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
I'm pretty sure you can order just the cover, but I don't know the part #. Someone in the 6.0L Diesel forum will know.
Old 07-24-2011, 10:55 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Moved to 6.0 forum
Welcome to FTE bherm
Old 07-25-2011, 07:55 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Think this might help:
http://www.ford-trucks.com/forums/93...eing-hfcm.html
And this one:
http://www.ford-trucks.com/forums/91...fuel-pump.html
Found these in Bismic's spread sheets. Nice tool to have layin' 'round.
http://www.ford-trucks.com/forums/75...wners-215.html
Old 07-25-2011, 12:26 PM
nylyon's Avatar
nylyon nylyon is offline
nylyon is gaining momentum as a positive member of FTE.
You'll need the new cover 6C3Z-9B249-A. Funny, I wasn't having any issues with WIF, but I wanted to drain it anyway and the plug was a problem for me too. I bought a new cover from a member here, and replaced it last year along with the updated drain plug. Well last week my WIF light came on. How nice to just crawl under the truck with a pair of pliers and remove the plug draining the water and fuel into a plastic container. Anyway, replace both the cover and the plug.
2011 F250 6.7 PSD WIF sensor RWC2504 6.7L Power Stroke Diesel 13 02-17-2017 12:53 PM
Heading to Dallas with Loss of Power & WIF & Glowplug light on! Peace2Peep Excursion - King of SUVs 1 05-28-2016 09:54 PM
New oil leak Bird-Dog 250 1987 - 1996 F150 & Larger F-Series Trucks 7 01-25-2016 10:44 AM
2004 F250 6.0 Rough Idle, Loses Power When Hot ten.mile 6.0L Power Stroke Diesel 3 12-12-2012 02:47 PM
Need a starting place for 6.0 Engine Issue ten.mile 1999 to 2016 Super Duty 2 12-11-2012 06:56 PM
Tags
03, 2006, 250, 60, diesel, drain, f250, filter, ford, fuel, light, plug, powerstroke, stripped, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
