glow shift guages any good?
That is the reason i bought them. It is also what i have used on two other vehicles, and never had issues with them.
I will give isspro a call.
What did you get? Didn't come with diagrams and instructions? Dad and I have had GS for years. No issues, Can't recall anyone complaining but yet hear they are junk.
Check this site out. Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Might as well give them a try... I have Isspro gauges with those silly "amp boxes" and i"ve had nothing but trouble with 2. I am about to just toss them and buy something else.
(coolant temp = goes haywire 90% of the time and is pretty much useless now)
(trans temp = does the same thing once in a while.... not very often but it is getting worse.)
I have checked and double checked all my connections to no avail... so it's gota be the boxes.
The "early" model Glow shift guages had some problems but they seem to have taken care of the problems and now have many happy customers.
I wanted to revisit this old thread since I am thinking about getting the 3 in1 EGT/boost/fuel pressure gauge. As I read this old thread I see some of you guys are still around and would like your feedback on the GlowShift 3in1 or EGT or fuel pressure. I currently am running Autometer but need a EGT. And if I can get a egt and fuel pressure for the price of a egt. It is a win win for me. I already have a boost gauge so I am wondering what I could use the other sensor for?
Now I have read MANY of guys saying Glow Shift are junk but yet they have never had them. Mind you I don't care to hear about what someone read on the interweb second hand. Even though everything on the interweb has to be true...right? I am looking for first hand experience good or bad. Because as I read some of the reviews online within the last 2 yrs it seems to be about 75% are having good luck and 25% have problems with them. Glow Shift seems to have worked thru most of the problems in the past few years so they say.
I personally only believe first hand experience.
Personally I don't care for the look of Glow Shift but since money is tight I mean very tight, if this 3-1 gauge will get the job done I can live with it.
Gauges are: boost 60, trans temp, fuel pressure, and egt...
I had thought about dropping the fuel pressure and running two egts...
I will let you know what I think when I get them in hand....
Trucks is going down for a tranny which is why I wanted to get this done now...
Can't help with experience yet....but I just ordered the Quad piller pod and max tow gauges for my '97....
Trucks going down for a tranny which is why I wanted to get this done now...
#28
I have no experience winth the 3in1
I retract my original post in this thread and I'll add that I also upgraded to dual pyros and added a fuel pressure gauge.
I went through 2 or 3 EGT gauges and 3 fuel pressure gauges and 2 sending units for the pressure gauges. By the end of it I didn't even bother putting the FP gauge back in I just threw it on a shelf in my garage.
I will say that their customer service was very good. Gauges that did last longer then the warranty then crapped out were replaced by new ones but not before getting ahold of GS and every time they were happy to discount the new replacements.
#29
Not the answer wise but first hand experience and down the road reviews.
But I am sorry to hear you have had these problems !!
#30
No problem I should have the gauges in hand this weekend... I will try and get pictures before install.
Yeah I kinda knew the tranny was suspect when I bought it in september...hoped to get more out of it before the OD flashing light issues and slip codes showed up.
