project 49 f-1
#31
#33
my dad has a catalog he found that show's a longbed option.
#34
The long bed option was an F-2 or F-3. Not an F-1. The transmission cross member is F-2/3. The synchro 4 speed was only available on the big models. The truck's straight cut spur gears will teach you to double clutch. The fact of it having rear shock absorbers would indicate that it is an F-2 rather than F-3 which normally wouldn't have rear shocks. Stu
#35
The oil leak is probably a seal. These old trucks are notorious for "marking their territory" with oil drips. The technology back then wasn't what it is today.
The transmission that you say is loose is more likely just the pin that holds the gearshift lever in place. If you unscrew the cap that holds the shifter in place and slide it up you will notice a slot on the driver's side of the tower. In that slot is a 1/4" x 5/8" pin. They get worn into an hour-glass figure just before they break. That's the most likely cause of the "row as you go" symptom. It can also cause your third gear grinding as the shifter isn't quite lining things up.
We just learned Canada offered the 255 flathead in F5's and F6's sometime during production and none of us here thought it was possible. Please scan your catalog so we can see the longbed option for F1's. Always willing to learn something new.
Tim
Tim
#38
but i don't care if it's a f-1 or f-2 as long as it looks good
#41
The vin number on your glovebox is ?98RC4..... (was hard to tell by the glare). But that's enough to tell you that particular tag came from a very late 1950 F1 with a flathead 8.
The firewall tag (again, correct me because the glare blocks it) said ?98RC363072 That is also a very late 1950 F1 flathead 8 vin number.
See if you can find the vin number on the frame rail.
#42
Enjoyed the pictures - looks like a good truck.
The serial number on the cowl tag and the "engine number" on the glovebox door should be the same number - which they are not. Both are from F1's and IMHO the cowl tag looks like it belongs on the cab.
As said before by somebody above, you'll have to get the frame number which is the only legal number today for most states. I'll still bet the 4th character is D or Y. Let us know when you find it please. We're curious now......
edit: mountaindoc, with a little photo tinkering I believe the glovebox tag is 98RC-467*** and I agree with '50 on both.
Curated Content Editor
10-19-2019 08:19 AM
Ancient Iron
28
10-25-2014 06:54 AM
Wayne Waldrep
09-21-2012 09:19 PM
