Ford F250 Custom ignition switch replacement....
Old 07-24-2011, 06:10 PM
dracolich's Avatar
dracolich
dracolich is offline
Hey everyone,
I drive a 1991 Ford F250 Custom 5.0L V8 Automatic 2wd, regular cab. For as long as I have owned the truck the ignition switch has always stuck a little when starting (usually a little worse in cold weather). But here in the last couple of days it has gotten much much worse. Now, when you turn the switch on you can get all the way to RUN and then no further, its locked and won't go on to start the truck. I figure now that I need to replace the key cylinder lock, and that's where the problem comes in.
I have been reading the posts about the switches and actuator rod over and over and over....but when I go to find the lock pin for the cylinder release...its nowhere to be found in the areas described. Why is it different from all the others and can anyone tell me where I need to go? Or might anyone have a diagram of that specific design for me to follow?
Thank you anyone and everyone for any help that can be given.
Old 01-21-2012, 08:22 PM
E-Jipt's Avatar
E-Jipt
E-Jipt is offline
The pin's location is circled in the red. You have to have your key turned to the run position I believe or else the pin will not be able to be pushed in allowing the lock cylinder to be removed.
Old 01-21-2012, 09:16 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1987 - 1996 F-150 & Larger F-Series Trucks forum.
Old 01-21-2012, 10:28 PM
E-Jipt's Avatar
E-Jipt
E-Jipt is offline
was wondering why that was in the test forum lol
Old 01-21-2012, 11:27 PM
powerstroke72
Probably a case of confusion where the OP didn't know where to post at the time. Rare but it happens....lol. Doesn't look like he's been back since posting that either....hmmm.
Old 01-21-2012, 11:48 PM
E-Jipt's Avatar
E-Jipt
E-Jipt is offline
ha, for some reason was thinking it was posted yesterday, but now I see >.>
Slyhuntr
03-31-2015 03:21 PM
jmh24
09-02-2010 06:16 PM
ocoee
11-23-2008 10:26 PM
DOUG5G
Aerostar
35
10-05-2006 04:29 PM
mopower
09-14-2004 10:08 PM
Quick Reply: Ford F250 Custom ignition switch replacement....
