Introductaion and oil pressure gauge question - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-14-2012, 10:28 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I have a cluster from a 94 Lightning. I would really like to do the oil gauge and sending unit modification. Is it really necessary to swap gauge internals? If so, do I just need a gauge from a 92 or 93 tach cluster or either cluster?
  #32
Old 02-14-2012, 11:12 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
I do not know about the 94 Lightning cluster but the 1994 & 1995 clusters are the same so I am guessing the 1994 would need the gauge movement also.
I put a 1992 F-series truck tachometer cluster into my 1995 F53 and the Mod worked right so know the 1992 movement works right.
  #33
Old 02-21-2012, 12:52 AM
stevetford stevetford is offline
stevetford is starting off with a positive reputation.
Wanted to add that on my truck, 1988 F250 4x4 460 there is no resistor on the back of the gauge cluster. The resistor is in the engine harness under the hood that goes across the firewall from driver side to pass side. On the wiring loom it is labeled "resistor" cut open the loom and there it is the 20 ohm resistor.
  #34
Old 06-15-2013, 05:43 PM
warren561 warren561 is offline
warren561 is starting off with a positive reputation.
Man am I glad that I found this thread. I just did this mod on my 96 F150 (4.9L).
It originally came with a non-tach cluster. I bought a tach cluster from a 96 F150 at the J/Y.
With the tach cluster in, I switched out the oil pressure switch with a new sensor (SW873B). I jumper-ed the resistor on the back of the tach cluster.
Quote:
Originally Posted by subford View Post
However, when I started the truck up, there was absolutely no change. The gauge didn't move at all when I rev'ed the engine. It seemed to act just as it did previously (with the old oil switch installed and resistor un-jumper-ed).
I took apart my 96 non-tach cluster. The oil pressure gauge on the 96 non-tach cluster did NOT look like what dixie460 found on his non-tach cluster.
Quote:
Originally Posted by dixie460 View Post
Instead, my 96 non-tach cluster basically looked like the 96-tach cluster, EXCEPT for the following (sorry, I didn't take pictures).
  • 96 non-tach cluster oil gauge had two windings (vs 1 winding)
  • 96 non-tach cluster oil gauge had a 92k resistor-type thing (didn't look like a traditional resistor, but it had 92k marked on it) soldered across the 9 o'clock and 3 o'clock poles, whereas the 96 tach cluster did not have this.
Basically, it looked like what subford mentioned below on his 95 non-tach cluster.
I just took a non-tach cluster apart out of a 1995 F150 and the oil gauge had both winding like the one you took out of a 199? truck.
I also checked it on the bench and the needle moved across the full scale using a resister sub box.
All of the drawing numbers on the cluster and module clusters had numbers that started with F4.
Also the Temp gauge winding were the same as the oil gauge and read the same across the scale with resister sub box.
I did notice that the oil and temp gauges had a resister pushed on to the signal and power pins. The resister for the oil gauge was 115 Ohms and the temp gauge was 95 Ohms. I guess these resisters supply current to make up a voltage divider between the resistance of the sender and the coil of the gauge for gauge calibration. These resistors are not shown on any of the cluster wiring diagrams from Ford.
In summary, I took the oil gauge from my 96 non-tach cluster (with 115k Ohm resistor between pins) and put it into my 96 tach cluster. The result is that the gauge moves when I press the accelerator pedal. The gauge moves from the "R" (at idle) to the "M" when I accelerate to 2,000 RPM. The gauge slowly moves back to "R" when I let it go back to idle.
If I get a chance, I'll try to look for a pre-95 non-tach cluster and report back if it makes my gauge move more.
I certainly don't see the type of movement shown in the video.
  #35
Old 06-15-2013, 05:54 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
I hope someone figures it all out one day.
Iʻd like to do this too.
  #36
Old 06-15-2013, 07:51 PM
subford's Avatar
I took the oil gauge out of a 1992 non-tachometer cluster and put in my 1995 stock tachometer cluster to get it to work right.
I think 1993 is the last year you can get oil gauge out of to make it work right.
There is a write up about this on this forum someplace.
  #37
Old 06-15-2013, 07:57 PM
khadma's Avatar
Carpenter Local 745
Iʻll keep this in mind, Iʻll JYing for a cluster.
  #38
Old 06-15-2013, 08:11 PM
subford's Avatar
The thread I was talking about is page #2 of this thread.
  #39
Old 06-17-2013, 11:14 AM
Yaga1973's Avatar
Yaga1973 Yaga1973 is offline
Elder User - What???
Yaga1973 is gaining momentum as a positive member of FTE.
Quote:
Mine does the exact same thing and I thought to myself, "So much for this mod." Now I know there is help as I still have my old gauge cluster sitting around so I can swap the other oil pressure guts into my new tach cluster. Thanks for posting this for us!
  #40
Old 06-17-2013, 12:11 PM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Oh man... I just read the entire thread again knowing I had posted in it originally and noticed I made some typo's... I certainly didn't mean that a reading of 0.3 ohms meant there was a resistor somewhere... guess I meant NOT a resistor somewhere lol...
I doubt it was a 92,000 ohm resistor... could it have been a diode? Did it have a symbol like ->|- that on it? I don't know what good that would do, either. The three pins are (IIRC) V+, V-, and signal.
  #41
Old 06-17-2013, 10:13 PM
So, when I made the observation that I posted above, the truck wasn't warmed up. I drove about 100 miles today. And the gauge moves a lot more once the motor is warmed up. Which makes sense as the oil is more "fluid" when at temperature.
With a warm engine at idle, the gauge reads at the "O." When I accelerate, the gauge moves. At about 2,500 RPM the gauge reads at the "M."
However, the gauge never seems to go beyond the "M" even when I'm at 3,000 RPM. So, I guess it works.
If I can find a 92 or 93 non-tach cluster at the J/Y, and the price is reasonable, I'll try to pick it up and steal its oil gauge to see if I can match what dixie460 did.
I'll try to take a photo of it. It definitely does not have 3 pins. It's two pins, dull yellow color and marked with 92k. Looks just like a resistor but without the resistor bands on it. Solid dull yellow color with 92k stamped in black ink.
dixie460, how much does your oil pressure gauge move? Does it seem to never go beyond the "M" even if you run the motor up to 3,000 or 3,500 RPM?
  #42
Old 06-18-2013, 09:00 AM
dixie460's Avatar
Warren561, on a cold start/idle my gauge reads just past the top of the NORM band, almost to the H mark. If I rev the engine any it will go over to H but I generally let her warm up at idle for at least a minute or so, more if it's a cold day.
Warm idle shows around the N in NORM, will go up to around the R with higher RPM's.
Don't remember if that is exactly where it goes... my oil gauge is acting up and probably fixin' to quit altogether. It's been sticking at the low end of the band since I pulled it apart to work on the cluster, although if I tap on it, it'll make it past the sticky spot and then stick again just before 3/4 scale. Need to get to the junkyard and grab another older cluster.
  #43
Old 10-15-2013, 10:27 PM
jas88's Avatar
jas88 jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I found another twist in the saga I want to add to this thread for posterity. I have a 1988 F250 donor truck that I used the diesel engine out of for my Diesel Bronco project. It's running, but I am working thru several electrical gremlins. One was that the OP gauge would read only halfway when grounded, but this is an '88 cluster (doesn't have a resistor) and '88 wiring that I put into my '91 Bronco. Because the OP did not have a resistor, I assumed this was an old-fashioned gauge. The motor did not have it's original sender as the PO had put in a mechanical gauge. I had a gauge sender laying around so I stuck it in there.
So, I have it running, and it is showing just barely any OP on the gauge. I ground it and it goes to halfway. So I start tracing back the wire, thinking I've got a bad connection somewhere. What I found was that they put the 20 ohm resistor in-line in the engine harness. I have never seen that before. I jumped that and now I have a real gauge, but it took me way too long to find it. I wasted a whole evening on that one thing.
  #44
Old 10-16-2013, 06:00 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Quote:
I found that resistor too before. Kinda makes you mad at Ford for that one!
  #45
Old 04-11-2014, 11:01 PM
Toplait's Avatar
Toplait Toplait is offline
Toplait is starting off with a positive reputation.
Bumping an old thread...Does it have to be a Non-Tach Cluster from a 92-93 cluster? Will a Tach cluster gauge work?
--Never mind I just read a post by Subford above and it answered my question....Thanks
This is the gauge out of my 92' Tach cluster..
1968 f100 Gauges Issues 68Rookie 1967 - 1972 F-100 & Larger F-Series Trucks 21 10-27-2016 03:57 PM
dash instrument cluster question / oil pressure / dc gauges Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 04-05-2016 08:32 AM
66 F100 Oil Pressure Sending Unit?? Death_Eagle_571 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-04-2015 03:15 PM
Anyone here know about oil pressure sending units? WXboy Oil & Lubrication 21 10-13-2009 11:22 PM
Oil Pressure gauge or sending unit? Dog_Brains Ford Inline Six, 200, 250, 4.9L / 300 5 06-29-2001 12:37 AM
Tags
1995, 1996, 75l, 85, 95, aftermarket, f150, ford, gage, gauge, installing, mod, oil, pegs, pressure, read, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
