4 wheel disc for the monster
Old 07-24-2011, 01:46 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
hey guys, havent been on for a little bit. between work, new girl and the beast i havent had much time. thought id throw some pics up though. 4 wheel disc now. did the cross drilled and slotted fronts, new lines, calipers, oem pads, bearings and seals up front, cross drilled rotors, 76-78 cadi calipers to the rear and new synthetic brake fluid though out. man.... crazy difference. that along with the hydroboost and this thing stops like a dream.
front
rear
Old 07-24-2011, 01:52 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
Looks frickin' awsome man.
Good job.
If you don't mind me asking how much did it cost and was it hard to do. Does not look all that involved, just a few adapters.
Old 07-24-2011, 01:54 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
Wish our trucks came like that! Hydroboost and discs all around. Looks good! Im sure it works good too
Old 07-24-2011, 01:59 PM
oreocreaming
rear was no sweat. just remove the axle shaft, remove the locking nut, slide the hub off and unbolt the backing plate. bolt the new adapter on with a 3/8" spacer on the inside of the flange and slip the hub back on. slip the rotor over the hub and bolt the new caliper on. you need the steel to caliper rubber line kit $45, the adapter plate $65, rotors $100, calipers $220, pads $15-150 depending on brand. if you have cores then the calipers are cheaper. its $35 core charge at kragen on each. cheaper then napa and autozone.
Old 07-24-2011, 02:00 PM
oreocreaming
thanks dirty.... it is the way our trucks should have come. they offered it on the f-superduty so why not at least an option on the f250-350 right? *******s....
Old 07-24-2011, 02:02 PM
'94IDITurbo7.3
Cool i would like to do this eventually.
Old 07-24-2011, 02:58 PM
Coalroller's Avatar
Coalroller
Coalroller is offline
oreo i bought that kit that you did basically the caliper mounts, where did you get the steel to caliper rubber kit and the 3/8" spacer from or if you have part numbers that would be awesome too! Also the adapter plate you speak of im assuming is the caliper mount bracket correct?
Old 07-24-2011, 04:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
wow.holy stopping power batman.
looks real nice oero.your bringing this old girl up into the 21st century.
Old 07-24-2011, 04:19 PM
Coalroller's Avatar
Coalroller
also are those wheel spacers on there so can fit your monster tires? or was that need as well for the swap?
Sorry for all the ?s man i plan to hopefully be doin this swap this winter or so
Old 07-24-2011, 07:02 PM
91dirtydiesel
Just wheel spacers I think I remember him telling me
Old 07-24-2011, 07:27 PM
FORDF250HDXLT
yeah,those are for running DRW on a SRW axle like i have too.but he's using 'em for monster singles lol.
Old 07-24-2011, 09:02 PM
Coalroller's Avatar
Coalroller
thats what i thought... just wanted to be sure lol
Old 07-24-2011, 09:15 PM
Wreckmaster's Avatar
Wreckmaster
Wreckmaster is offline
Looks badass... What are you doing for a parking brake? Or is it already built in?
Old 07-24-2011, 09:32 PM
sak778's Avatar
sak778
sak778 is offline
Thats why he's using the expensive caddy rear calipers. instead of the cheaper chevy pickup front calipers.
YMMV
Old 07-24-2011, 09:36 PM
Wreckmaster
So they're built in? Dang.. nice. Wish I knew that when I did the axle swap in my jeep cherokee.. Put in a D60 and had to fab up a line lock for a parking brake.
Quick Reply: 4 wheel disc for the monster
