Will a c5 lockup converter work in a c6? - Ford Truck Enthusiasts Forums
Old 07-24-2011, 01:25 PM
401477534 401477534 is offline
401477534 is starting off with a positive reputation.
I notice that when looking at torque converters online for the c6 it usually show c4-c6 converter, and c4,c5,c6 converter...so I imagine they are all interchangeable...but does the c5 lock up torque converter work in a c6? I thought I heard somewhere they were centrifugal. (Im not sure) Even if I could do it my engine would probably smoke it pretty quick...but I just thought Id ask. It would be interesting, a lock up c6.
Old 07-24-2011, 08:02 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
No its not possible, even if you had a C5 you wouldn't want the lock up to work because it was such a poor design. I used to disable the lock up in all C5's I built because there was so many problems with them they wouldn't stay gone long.
Old 07-24-2011, 11:05 PM
Quote:
I heard there were problems with them...were they any good even in a stock application? Or were they always just overall bad?
Small C6 Torque Converter 72earl302 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-28-2012 12:33 AM
C4 Confused....advice needed craigibc Clutch, Transmission, Differential, Axle & Transfer Case 1 03-14-2012 08:28 AM
C5 transmission rebuild adaag53 Bronco II 8 11-11-2009 11:55 AM
Lock-up torque converter for C6? Piffery1 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-03-2004 08:55 AM
C6 torque converter lockup farmpaw Clutch, Transmission, Differential, Axle & Transfer Case 3 08-12-2001 06:39 PM
Tags
c4, c5, c6, controls, converter, converters, convertor, ford, interchangeable, lock, locking, lockup, torque, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
