HELP PLEASE!! 97' turbo removal 7.3 diesel
I need some help/advice. I'm replacing fuel pump/dampner. Does the turbo have to be removed to replace this??? The banjoe lines on the pump are not fitting under the turbo. What do I do???
Is there a trick to this job, without removing the turbo??
Thank You. Tim
Thank You. Tim
https://www.ford-trucks.com/forums/1...l+pump+removal
Need more links, just search for fuel pump removal, that is what I did and got many results, these are just 2.
Also, welcome to fte!
1989f250IDI
21
05-15-2013 10:13 PM
alvin431
02-19-2011 03:26 PM
aussie01
12-14-2008 03:32 PM
