HELP PLEASE!! 97' turbo removal 7.3 diesel - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-24-2011, 07:06 AM
Boatworksdive Boatworksdive is offline
Boatworksdive is starting off with a positive reputation.
I need some help/advice. I'm replacing fuel pump/dampner. Does the turbo have to be removed to replace this??? The banjoe lines on the pump are not fitting under the turbo. What do I do???
Is there a trick to this job, without removing the turbo??
Thank You. Tim
Old 07-24-2011, 08:06 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
It does not have to be removed for the fuel pump, I'll see if I can find a link for ya
Old 07-24-2011, 08:11 AM
http://www.ford-trucks.com/forums/10...l+pump+removal
Need more links, just search for fuel pump removal, that is what I did and got many results, these are just 2.
Also, welcome to fte!
Old 07-24-2011, 12:22 PM
thebig350's Avatar
thebig350 thebig350 is offline
thebig350 is gaining momentum as a positive member of FTE.
I replaced mine without removing the turbo, it was probably a little more difficult because I didn't, but it can be done. I had one of my 9 year olds thread the banjo bolt back on since my hand is too big to fit under there, that was the only 'special tool' I needed.
turbo removal wattrode 1994.5 - 1997 7.3L Power Stroke Diesel 31 08-08-2016 05:41 AM
Please help....2002 7.3L turbo removal amistybleu 1999 to 2016 Super Duty 1 02-10-2016 02:45 PM
2004 F-250 6.0 L Turbo Installation jetlr1 6.0L Power Stroke Diesel 4 09-25-2014 07:55 AM
Help in removing turbo bvplus2 User Gallery & Picture Display 1 04-07-2013 02:51 PM
leak from Injector pump, need help ASAP calialx1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 03-20-2011 08:42 AM
Tags
1997, 2000, 2001, 64, 73, 95, 97, diesel, f150, ford, obs, powerstroke, removal, remove, trubo, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
