6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
LED turn signal lights
Old 07-24-2011, 12:10 AM
mlbmd's Avatar
mlbmd
mlbmd is offline
I have installed projector headlights with xenon bulbs and LED turn signal lights.
The turn signals flash rapidly, and I have even installed resistors to try to correct this, but to no avail. Any ideas on how this might be corrected.
Is it true that the signal flasher is computer controlled and the dealer can adjust it.
Or, is there a flasher module that needs to be changed?
Any ideas will be greatly appreciated. All works well with the original incandescent bulbs.
Old 07-24-2011, 06:13 AM
pbeering's Avatar
pbeering
pbeering is offline
The PCM controls turn signals (and lots else). All the new trucks are very finicky about electric load, resistance, etc. The LED lamps draw less and confuse the PCM. You should have the dealer apply the snow plow lighting update to the PCM and see if that fixes the issue. That update was designed to allow different lighting loads.
Old 07-24-2011, 03:50 PM
bnmccoy's Avatar
bnmccoy
bnmccoy is offline
Old 07-24-2011, 07:06 PM
pbeering's Avatar
pbeering
pbeering is offline
Thanks loads to bnmcoy for those links!
dmarsh2400
08-19-2019 03:23 PM
DeeDubz
6.7L Power Stroke Diesel
13
05-17-2016 12:05 PM
pdqracer
2009 - 2014 F150
10-31-2015 03:24 PM
hacking_in2002
06-12-2009 09:36 PM
Frost_26
1978 - 1996 Big Bronco
16
05-06-2006 03:33 PM
Quick Reply: LED turn signal lights
