Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-23-2011, 04:47 PM
2009Exp 2009Exp is offline
Garage is empty, add now
2009Exp is starting off with a positive reputation.
Question Weird AC Noise Issue
I am having a weird issue with my Air Conditioning making noise.
My truck is a 2009 Ford Expediton XLT with 22,000 miles.
When you turn the key to the on position, it makes a tapping noise. This sometimes continues for a while if its on all the way cold. A YouTube video is below of the issue. If you adjust the temperature from all the way cold, the noise stops. However, if you put it back on all cold, it starts up again.
Also, it just had the 20,000 mile service done. It started doing it after that.
‪Ford expedition 2009 weird problem‬‏ - YouTube
Do you guys have any idea what is causing this? Would I be able to fix it myself? Thanks.
  #2 (permalink)
Old 07-24-2011, 11:23 AM
SickPup404 SickPup404 is offline
SickPup404 is starting off with a positive reputation.
I have no definite answer, but I'd check the belts to see if there's anything too loose or too tight (binding up?) and maybe see if there's a prob with Freon - is is getting cold enough?
Do you know if they serviced the AC? Wondering if something was left un-done...
__________________
Steve
2007 Expedition EL Limited
  #3 (permalink)
Old 07-25-2011, 11:38 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Might be the vent door motor. Does it make the same sound with the re-circ button not lit?
__________________
See ya,
Eric
  #4 (permalink)
Old 07-26-2011, 05:19 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I going to say that's the motor on the blend door. The blend door is notorious for sticking/groaning/moaning and just flat out not working.
That sounds like the pawls on the motor clicking through the gears. How cold is the air coming out of the system?
__________________
Chandler
Official Slackmaster #24
  #5 (permalink)
Old 07-26-2011, 10:54 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
My vote is blend door motor gears are stripped. It's under warranty so take it in.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
2008, 2009, 2010, air, airconditioner, conditioner, conditioning, e150, f150, ford, makes, navigator, noise, noisey, truck, weird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
