Vacuum Line by ABS Module - Ford Truck Enthusiasts Forums
Old 07-23-2011, 12:58 PM
ChrisCarter ChrisCarter is offline
ChrisCarter is starting off with a positive reputation.
I got a vacuum line on my 2004 Ford F150 that is just hanging loose. Its near the ABS Module thingy on the driver side. There looks to be two, one goes down and over towards the passenger side, and this one seems to just come up and stop right at the ABS module, however its unplugged and I can't figure out where it goes. Does anyone know? My ABS light was on yesterday for a bit, it went off and on, had the codes read and it was something to do with the rear abs sensor malfunctioning, and no network communication, but it hasn't been on since, however my truck is running a tad bit sluggish when accelerating, and I gotta figure its that vacuum line. I just had my phasers done and I assume it must of been knocked loose during the guy working on it.
Old 07-23-2011, 02:07 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is online now
xjcamaro89 is gaining momentum as a positive member of FTE.
I believe that line is the vent line for your vacuum actuated 4x4 hub down behind your spindle. Crawl under the truck and take a look. Also you should have a matching disconnected line on the other side. They are supposed to be disconnected. (Now im on my phone looking at this and the pictures don't show real good on my phone) but that's more than likely what it is. For more info read the thread that there is a link to in my signature
Old 07-23-2011, 02:22 PM
This has suction when the truck is running don't think it's supposed to be disconnected.
Old 07-23-2011, 02:54 PM
xjcamaro89's Avatar
Oh.........well crawl under the truck. There is a ring behind the steering knuckle that the front half shaft goes through.that ring should have a double vacuum line connected to it that routes up and through the area you are talking about. Make sure that line was not disconnected and left to hang and that is what your seeing. If it was then your front hubs would be engaged and the trucks intake would be constantly sucking in extra air by means of that vacuum line.
I guess you need to track where exactly that disconnected line runs to and to what and where and let us know so we can tell you exactly what its for
Old 07-23-2011, 02:56 PM
xjcamaro89's Avatar
Sorry I have more. If it is that line I described earlier. Than its the vacuum line that runs you 4x4 system and needs to be connected properly
Old 07-24-2011, 11:38 AM
These lines run by the steer knuckle. There is two of them side by side, one like I said runs down and over and the other one was sticking up, but it may of went down to and connected some where, but I can't figure out where. I am utterly confused as to where it goes. It feels like it has suction to it, and like I said my ABS is randomly acting up on me, giving me network communication errors to the rear speed sensor, and I just replaced it yesterday to make sure that wasn't it, and still every once in awhile getting the same random ABS issue. Its got to be related to the vacuum leak.
Old 08-20-2011, 04:15 PM
superhomey superhomey is offline
superhomey is starting off with a positive reputation.
Chris, did you get the answer to your question? I too am having brake trouble and noticed the exact same vacuum line open ended. My front driver's side caliper locks up and doesn't release pressure. The shop replaced the front calipers, pads and hoses. Now they are saying it's contaminated fluid, but I checked and it's fine. I started snooping around and saw the open ended line at the ABS box and wondered if it should be connected somewhere.
Old 08-20-2011, 04:54 PM
Quote:
Yea apparently according to the dealer the line is just a breather.
What did you do to the X today? Snowseeker Excursion - King of SUVs 44813 Today 08:55 PM
New Member..New Owner.. RussEx Excursion - King of SUVs 10 02-09-2015 10:05 PM
Rust repair, what us salt belt guys have to put up with Snowseeker Excursion - King of SUVs 34 08-04-2014 09:21 PM
Rust repair in the salt regions. Snowseeker 1999 to 2016 Super Duty 24 08-02-2011 10:40 AM
Custom made door panels Casey_78 1973 - 1979 F-100 & Larger F-Series Trucks 32 01-04-2009 09:39 PM
Tags
150, 1999, 2000, 2005, 2006, 2007, abs, axle, f150, ford, line, lines, modulator, module, pictures, rear, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
