Schrader Valve - Ford Truck Enthusiasts Forums
Schrader Valve
Old 07-23-2011, 11:42 AM
mighty300 mighty300 is offline
mighty300 is starting off with a positive reputation.
Schrader Valve
I am currently working on a 1988 F-150 300 I 6 and am having problems with running at higher rpm's. I am wondering if the fuel pressure might be off, and was wondering if this vehicle has a schrader valve with which to check. Also, where could i get a manual for this vehicle?
Old 07-23-2011, 12:52 PM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
A Haynes manual is a good investment and can be found at most auto part stores for less than $30. I found mine at a local bookstore that was getting ready to close and paid $10. It's not the best of course but it has most of the basic info you will need, fluid capacities wiring and vacuum hose diagrams etc.
There are better books out there but can be expensive.
Old 07-23-2011, 03:10 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Yes it has a schrader valve that you can check the fuel pressure.
Just short pin#2 to pin#6 of the self-test plug and you should get around 60 PIS with engine not running and the key on.
Schrader valve location:
fuel pressure gauge on 1995 F350 7.5 fuel rail lisagoud 1987 - 1996 F150 & Larger F-Series Trucks 4 07-06-2016 05:14 PM
looking for schrader replacement options IDIoit Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-05-2016 01:32 PM
proper way to test Fuel Pressure Flat Boosted 1999 to 2016 Super Duty 4 02-20-2013 12:12 AM
Add schrader valve to test fuel pressure cef2lion 1999 - 2003 7.3L Power Stroke Diesel 5 11-17-2006 12:40 PM
Schrader valve dino360 Cooling, Heating, Ventilation & A/C 6 09-17-2004 01:15 PM
Tags
00, 1996, 2005, 60, engine, expedition, f150, f350, find, ford, fuel, inline, pressure, schrader, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
