Brake job goes wrong
Vehicle: 1995 F-150 4.9. Problem. First the brakes would shudder and shimmy after warming up--in my experience a sign of warped rotors or bad pads (not worn out, but cracked or fragmented, etc.). Anyway, I had the rotors turned and got new pads. When I was reassembling the left side I noticed that the piston in the caliper didn't want to go back in. The right side pushed smoothly into the caliper (I use a big clamp), no problem. The left one had to be forced by adding leverage to the crank of the clamp. Put it all back together and now it pulls HARD to the right, like the piston is not pushing out on the left side, or there's a brake fluid leak on the left side--but I don't see any brake fluid dripping or running out--, or there's air in the line. I've never had air get in the line when just changing brake pads. In any case, I'll probably disassemble it tomorrow morning and check it out. Too hot to work on it any more today (about 105). Any thoughts? Can a reluctant piston be lubricated somehow?
Keith
Keith
I agree with ''blk'', and I agree with ''White''. So I guess I can say its as clear as black and white. Ha. Ok...
But yes.. Replace both calipers and both hoses. As old as everything is.. No use in fixing something and having to fix something else in common shortly thereafter. You will be back on the road in no time.
you can check this pump the pedal a few times with left side in the air then try to turn wheel if you cant the crack the bleed screw if it shoots out just a bit then nothing (close bleeder ) check the wheel again if it turns then you have a bad hose but the clipers are fairly cheapand ive seen the hose material get in the caliper also and note you can rebuild the calipers also real cheap not hard just a thought
Restlesswildman
06-18-2014 07:19 PM
