Unit bearings - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Unit bearings
Old 07-23-2011, 11:39 AM
74baja's Avatar
74baja 74baja is offline
74baja is starting off with a positive reputation.
Unit bearings
Hey Folks,
I'm pretty sure my front passenger's side main bearing is going out. I lost the driver's side about 20k miles ago, now I feel/hear some similar rythmic clunking from the passenger's side. I'd like to be totally sure before ordering the part though. Could it be the other bearing up there (needle bearing?) Also, I was advised to buy the Timken assembly from rockauto. I'm SRW 4x4, but they have one with fine thread studs and one with coarse thread studs (coarse is about $15 more.) Are these the wheel studs? How can I be sure which I have?
Thanks,
Jack
Old 07-23-2011, 01:08 PM
arto_wa's Avatar
arto_wa arto_wa is offline
arto_wa is starting off with a positive reputation.
Wheel studs
The fine thread studs have 1.5 mm pitch, the coarse threads have 2.0 mm pitch.
Just measure the thread pitch to see which ones you have, the difference is obvious.
Old 07-23-2011, 01:44 PM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
Quote:
Originally Posted by 74baja View Post
Hey Folks,
Thanks,
Jack
Hi Jack, yes the wheel studs is what they are talking about. Your truck should have the coarse thread wheel studs. I believe the change was made in 2002 to fine thread.
Best way to know for sure is to check a wheel stud with a pitch gauge.
Old 07-23-2011, 02:49 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
If you want to be sure, they are not that hard to pull so you can check the needle bearing. I got Timken's at my local NAPA but had to ask for the USA made units. They also offer a cheaper one made in china. They had both in stock.
Old 07-23-2011, 02:59 PM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Best to check the pitch. Maybe buy a couple lug nuts, corse & fine if you dont have a pitch gauge. Mike said in post 43 his 03, 250, 4X4 had fine threads studs in this thread. Hope this helps.
http://www.ford-trucks.com/forums/10...g-apart-3.html
Old 07-23-2011, 03:23 PM
74baja's Avatar
Thanks guys, I'll check the pitch.
I think I'll order the unit bearing from rockauto, and check it when I have the old one apart. If the needle bearing seems to be the culprit, I'll buy one and return the unit bearing. I just want to get the good deal on rockauto, unless my local parts house has it cheap.
Thanks again
Old 07-23-2011, 06:47 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
buy the cheapest one and change the studs if they are wrong. it is all of 5 minutes to change them.
Old 07-23-2011, 10:39 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
But DON'T use a hammer to remove the lug bolts and install the correct ones!!!
No hammer!
Pop
Difference between Timken 515020 & SP580205 Front Bearing Assembly Lex2002 1999 - 2003 7.3L Power Stroke Diesel 14 06-22-2016 06:10 PM
Exhaust manifold Thatrooper515 Modular V10 (6.8l) 0 08-15-2015 11:46 PM
2004 front wheel bearing replace Diamnd1 1999 to 2016 Super Duty 4 02-19-2015 09:35 PM
2003 f250 4x4 SRW Hub Assembly - Fine or Coarse ?? CJ2003F250SD 1999 to 2016 Super Duty 7 10-15-2014 03:01 PM
Coarse or Fine Thread Studs? atruscott 6.0L Power Stroke Diesel 6 06-05-2014 04:12 AM
Tags
60l, bearing, bearings, f250, ford, studs, temperature, truck, trucks, ubit, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
