Holley 600 carb on fe 360? - Ford Truck Enthusiasts Forums
Old 07-23-2011, 10:23 AM
brigga72 brigga72 is offline
brigga72 is starting off with a positive reputation.
I just aquired a holley carb with the list number 80457-5. My question is what, if anything, will I need to fit this to my 360 engine.
Thanks for any information.
Old 07-23-2011, 02:30 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I think that's an "S", and not a 5 at the end of the PN in your post. Hence, 80457-S which is a a 600 cfm vac secondary with electric choke.
You'll need a 4 bbl intake... either a stock 4 bbl intake or Edelbrock Performer PN 2105. Opt for an open element air cleaner and filter.. it's a very cheap upgrade and worth a few HP, even on a 2 bbl. A 4-hole phenolic spacer is worth some low and mid-range RPM torque. To make the best of the 4 bbl induction however, consider installing headers and dual exhaust system before the carb upgrad.e
The throttle linkage may need some mods. Mine had a bell crank mounted on the intake in between two rods on either side. I had some extra Mustang parts and installed a single rod between the carb and the bellcrank mounted on the firewall.
I suggest doing a carb rebuild to establish a known good baseline.
Old 07-23-2011, 08:35 PM
mjshagnasty's Avatar
mjshagnasty mjshagnasty is offline
mjshagnasty is starting off with a positive reputation.
If you want real cheap install opt for a 2 to 4 carb adapter they sell them at carquest.
holley carb installation advise Nick-1973-ford 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-17-2016 07:29 PM
4 barrel carb on a 360? forestgreen 1967 - 1972 F-100 & Larger F-Series Trucks 4 07-09-2015 08:29 PM
360 to stroker 445???? xtraparts FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 08-29-2013 09:24 AM
big Holley dpoelstra Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 07-11-2002 11:00 AM
Jet size help 73Ranger FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 01-24-2002 09:13 PM
Tags
1967, 2v, 360, 390, carb, carbs, carburator, carburetor, engine, f250, fe, ford, holley, motor, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
