Dana 60 alignment specs - Ford Truck Enthusiasts Forums
Old 07-23-2011, 09:53 AM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Anyone have/know the specs for the Dana 60's? Seems the crew cab has an issue, drivers side has too much inward lean (camber). Anyone know how it can be adjusted, and what the spec should be?
Old 07-24-2011, 11:40 AM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Only the toe is adjustable on a stock dana 60. You can get aftermarket kingpins that can adjust either the caster or camber (don't remember which). You can also get spindle shims that will do a bit of adjustment as well.
Old 07-24-2011, 10:29 PM
Guess I need to tear into it then and see what I find, drivers side front leans in almost an inch at the top of the wheel, and is badly wearing the inside of the tire.
There's no play in it though, and I've checked it a couple times now, and no sign of any damage, things being bent etc. I want to put new u joints in it anyway, so I think I'll tear it down and see. Maybe it has the adjustable kingpins and something has moved, who knows.
Old 07-25-2011, 12:44 AM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
something would almost have to be bent or otherwise fubar'd. my 60 has a pretty good amount of camber, but it should be the same on both sides, and the top of the tire should lean out, not in
Old 07-25-2011, 01:01 AM
I kept thinking it looked funky, so I used a 2' level to check the tire for plumb. Passenger side was in at the top maybe 1/8", driver's side close to an inch. I think the toe-in is out a little too, or, actually in a little, checking with a tape it seems a bit more than normal, but with the one tire worn funny, it's harder to measure.
I've jacked it up twice now, used a bar to check for play in different directions, no noticeable play in the kingpins, tie rod ends, springs, etc. I would think that to be out of whack as far as it is, something would be visible, either slop, or damage, but no signs of anything.
Old 07-26-2011, 11:29 PM
mlouritt's Avatar
mlouritt mlouritt is offline
mlouritt is starting off with a positive reputation.
My book states alignment specs for a 91 F350 4x4 are : Caster 2 P-4 3/4 P (positive), Camber 0, Toe 0.5 inches out. It also states for a monobeam front axle the upper kingpin is tightened to 500-600 foot pounds. Good luck with that one!
Old 07-26-2011, 11:41 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
with the price of fuel and tires,it would actually pay you huge to just pay a shop to align her.you'd get all the $ back and then some in short order.
Old 07-27-2011, 12:23 AM
Quote:
Thanks for the info!
Actually, 5-600 ft lbs isn't hard to do, tractor trailer lug nuts are often in the 450-500ft-lb range. A 3/4" drive torque wrench should cover that high a torque.
Guess I'll tear into in the next couple weeks when I get some time, see and go through it, then get the alignment done. Being in rust country, it's always cheaper for me to spend time freeing frozen/rusted bolts than to pay hourly shop rates for them to do it.
Old 07-27-2011, 12:41 AM
chances are pretty good that you wont have to replace the the king pins themselves. the uppers have a nylon bushing in them with a spring to pre load, and the lowers have a tapered roller bearing, unless there real scored up, you usually just need to rebuild
Old 07-27-2011, 06:54 AM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Well I am learning more and more about the suspension every time i see these posts....although there is never a post about the D44...I trust it....but nobody else does...
Torque specs green_95 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-17-2016 01:37 PM
dana spec help! tlmb023 1967 - 1972 F-100 & Larger F-Series Trucks 0 10-25-2011 12:04 AM
tourge specs for spindle nut joe f350 Offroad & 4x4 8 12-28-2010 06:46 AM
Dana 44 vs. Dana 50 vs. Dana 60 vs. Sterling 10.5 ????? Waxy 1999 to 2016 Super Duty 14 10-19-2010 12:32 AM
Torque spec Dana 80 GTOBRIAN Clutch, Transmission, Differential, Axle & Transfer Case 0 12-07-2009 08:53 AM
Tags
1987, 60, 91, alginment, alignment, cab, camber, crew, dana, f250, f350, gross, spec, specs, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
