gear shift collar kit,# D5TZ-7228-A
Old 07-23-2011, 07:48 AM
H00TY1's Avatar
H00TY1
H00TY1 is offline
Hi guys and girls, I have a question on how to install a Dorman # 83242 Gear shift collar kit. This is for a 1968 ford f100, this is a common problem of them breaking. When I look at the unit on truck I can't figure out how to remove the wires, that is the most important part to me. I have tried everything, I think, but still can't remove the whole unit to replace it. Does anyone know if there is instructions with this kit. Also I might not use this kit, I might buy the one out of LMC since its a direct fit. They say the 73-77 kit will fit the 60's trucks. This is an automatic D,2 and 1,also no hazard light button. Any help would be great. Thanks, hooty1
Old 09-02-2014, 05:20 PM
faof2's Avatar
faof2
faof2 is offline
Here we are six years later and I have the same question. Did you find out what to do with the wires to the horn and signal indicator when you R&R the shifter collar?
Jerry
Old 09-02-2014, 07:47 PM
RichS2659's Avatar
RichS2659
RichS2659 is offline
Orich gives a good description of how to do it in the jlasater's post of the same problem.
Old 09-02-2014, 08:00 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Jerry
Attach twine or wire to the T/S's wires down below. This twine will come up with the T/S switches wires. Leave the twine there. After changing the shift collar use the twine to pull the wires back down.
fordsforever2015
11-12-2021 11:35 PM
tbear853
21
02-05-2021 08:25 PM
Uni Moe
21
06-30-2017 11:04 AM
Midnight Garage
08-09-2016 04:59 PM
Old_Crow
20
06-30-2015 04:20 AM
Quick Reply: gear shift collar kit,# D5TZ-7228-A
