Gibson Tri-Y vs Doug Thorley Tri-y???? - Ford Truck Enthusiasts Forums
Old 07-23-2011, 03:23 AM
Subi69 Subi69 is offline
Subi69 is starting off with a positive reputation.
Im looking at getting a set of tri-y headers. As I have been doing alot of research. I have almost everything done so far as "Project M.P.G." except for headers obviously and Im ordering my AFPR and gauge next week. Then maybe work on the bbk 61mm TB after headers. I have been reading that the tri-y headers offer more low end tq then the long tube ones.
Im going to take my air pump off after I go through emissions. But my question which is better? Gibson or Doug Thorley? Or is there another company that makes a set of Tri-y headers.
I was planing on running headers then 4" random tech high flow cat then 4" bullit muffler then 4" pipe out to behind the rear wheel. Im keeping it single cuz I have the dual gas tank and I have most of the 4" pipe from a stock dodge diesel
Thanks fellow 460 owners for all your help and input.
Old 07-24-2011, 02:04 PM
Well noone has chimed in to say which is better.
But I have been doing alot of searching for prices:
Best price so far on gibson was 628 then I just found a set new for 528
The thing with gibson they are only nickel chrome plated.
Doug's are nickel chrome or ceramic. I would rather have ceramic but I can always just heat wrap them before install.
The prices so far on the doug's match the high price of gibson 736 but thats CC.
Im going to keep doing more searching and Ill update when I have more info.
Thanks Clay
Old 07-25-2011, 10:01 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Thorley's been doing the Tri-Y thing for as long as I can remember. I want a set for my 460 eventually too and I am planning to go with the Thorley's in order to get the ceramic coating.
Old 07-26-2011, 10:02 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Can't really comment on the headers except to say that I've only heard of Doug Thorley's Tri-Y, so that's probably worth something.
But I will say, 4" is probably going to be too big of exhaust for an otherwise stock motor. Most people recommend 3" if you're running single exhaust.
Old 07-29-2011, 12:50 AM
OldRacerGuy's Avatar
OldRacerGuy OldRacerGuy is offline
OldRacerGuy is starting off with a positive reputation.
I'm going with a 3 1/2" single to replace my 3". Banks kits use 3 1/2" and they do more testing than anyone else so I'm following that lead.
Tri-y headers on a dent axelgawn 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-28-2016 06:28 PM
Carb vs FI Heads & Tri-Y Headers Mickser 1987 - 1996 F150 & Larger F-Series Trucks 2 01-28-2016 11:34 AM
Has anyone tried SBF Mustang Tri-Y headers in 65-79 truck? Nate66stepside 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-20-2015 03:07 PM
Doug Thorley Tri-Y Headers smog in ca rockcrawler_101 Excursion - King of SUVs 5 09-30-2013 01:42 PM
2003 V10 Exhaust Headers bakon 1999 to 2016 Super Duty 21 04-30-2010 08:49 AM
Tags
1977, 385, 460, 75, doug, excursion, f150, f350, ford, gibson, headers, review, thorley, tri, triy, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
